In search for gaskets.....HELP!!!
Old Oct 31, 2005 | 04:59 PM
VisualAutoMotoring's Avatar
Default In search for gaskets.....HELP!!!
Trying to finish the car already so help me find these 2 gaskets
Old Oct 31, 2005 | 07:22 PM
vaporboy12's Avatar
atpturbo.com?
Old Oct 31, 2005 | 09:39 PM
D@nnY's Avatar
Default Re: (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">atpturbo.com?</TD></TR></TABLE>
Old Nov 1, 2005 | 04:12 AM
Checked they dont have the 6 bolt one nor the right diameter for the 3 bolt one
Old Nov 1, 2005 | 08:07 AM
yee SERIOUS's Avatar
why not make it? i bought some high temp gasket material from napa for 26 bucks i think. and it was big enough to make a few gaskets. i think the size of it was 12x48 for the sheet. just tell them you need the gasket material that goes off the turbo.
Old Nov 2, 2005 | 05:52 PM
Default Re: (undercoverdc2)
bump for some help
Old Nov 2, 2005 | 05:58 PM
EVIL Hx Coupe's Avatar
Default Re: (Hybrid-Performance.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com &raquo;</TD></TR><TR><TD CLASS="quote">bump for some help</TD></TR></TABLE>
I used that gasket sheet from napa about a year ago and made gaskets for my firend turbo setup. It's up just fine, and still no leaks. Now I'm using the same material again to make my new gaskets for my own setup .
Old Nov 2, 2005 | 11:12 PM
KeyserSoze's Avatar
Default Re: (EVIL Hx Coupe)
What are the gaskets for??? Water, oil, exhaust?? If you fax me an outline of them with a desired thickness and say pretty please I can make you some if we have the appropriate material here @ work. I work at a power plant so we have all kinds of gasket material, from oil, water, hp steam (2000psi+ and rated @ 1600 deg F). Lemme know.
We have lots of different kinds of chesterton gasket material. The hp steam gasket material is the chesterton 359.
Old Nov 2, 2005 | 11:44 PM
HYBRID_H@TCH's Avatar
Default Re: (KeyserSoze)
I had to make some one off gaskets before..I went to a local hobby shop and got some copper sheets and made gaskets..held like a champ..
Old Nov 3, 2005 | 04:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">What are the gaskets for??? Water, oil, exhaust?? If you fax me an outline of them with a desired thickness and say pretty please I can make you some if we have the appropriate material here @ work. I work at a power plant so we have all kinds of gasket material, from oil, water, hp steam (2000psi+ and rated @ 1600 deg F). Lemme know.
We have lots of different kinds of chesterton gasket material. The hp steam gasket material is the chesterton 359. </TD></TR></TABLE>
They are exhaust gaskets from a RB25DET Nissan motor. Basically its the turbine extension outlet gasket and then outlet downpipe gasket.
Old Nov 3, 2005 | 05:37 AM
raiden571's Avatar
just make your own, and then buy some high temp gasket sealer. we sell ti all the tim at advance auto, its like this nasty grey **** and its uber tacky. used it on my DP with a gasket and i havent had one leak with it yet
94lspower
May 9, 2007 02:53 AM
DC4KiD
Northern California (Sales)
Jun 11, 2006 02:52 PM
turbochargeb18c
Mar 5, 2006 12:39 PM
AutoxEK9
Jul 28, 2005 09:27 AM
94HatchbackSI
Sep 27, 2004 01:39 PM
