Sea Foam??
Old Apr 17, 2004 | 01:44 PM
  #26
keebler65's Avatar
Default Re: Sea Foam?? (Blue-Civic-Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue-Civic-Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">What about just pouring it directly in the engine for us with JRSCs? I thought it was designed for pouring it into the oil and running for about 15 minutes then doing an oil change...?
Am I wrong in this approach?</TD></TR></TABLE>
i'm just afraid of it going through the blower though.....i dont know if that would cause any damage to the blower.
Old Apr 21, 2004 | 05:30 PM
  #27
BodyKits NW's Avatar
Default Re: Sea Foam?? (keebler65)
Does this stuff also clean out the exhaust? If not is there a cleaner that you can purchase that will help clean out the carbon deposits within the exhaust system? C
Old Apr 21, 2004 | 05:36 PM
  #28
igo4bmx's Avatar
Default Re: Sea Foam?? (BodyKits NW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW &raquo;</TD></TR><TR><TD CLASS="quote">Does this stuff also clean out the exhaust? If not is there a cleaner that you can purchase that will help clean out the carbon deposits within the exhaust system? C</TD></TR></TABLE>
Also I am pretty sure I saw a thread a while back about a Honda version of something like this to clean out the engine ... damn now i need to find the thread....
Old Apr 21, 2004 | 05:43 PM
  #29
AlphaKennyWun's Avatar
Default Re: Sea Foam?? (igo4bmx)
my turbo cleans out the carbon in my exhaust when i step on it
Old Apr 21, 2004 | 07:05 PM
  #30
Boltz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 &raquo;</TD></TR><TR><TD CLASS="quote">
i'm just afraid of it going through the blower though.....i dont know if that would cause any damage to the blower.</TD></TR></TABLE>
it wouldnt matter because it goes through your fuel system.
Old Apr 21, 2004 | 07:58 PM
  #31
Mr. Softee's Avatar
Default Re: Sea Foam?? (Boltz)
as I've stated, I just drive my car in the ocean.
Old Apr 21, 2004 | 08:58 PM
  #32
ringgold's Avatar
Default Re: Sea Foam?? (94goldjungsr)
Im gonna try to find some of this stuff and give it a try! maybe this weeked or wait maybe not this weeked but the next. when i get my hands on some Ill let you guys know how it worked.
Old Apr 21, 2004 | 09:07 PM
  #33
mskibbz-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">
Also I am pretty sure I saw a thread a while back about a Honda version of something like this to clean out the engine ... damn now i need to find the thread....</TD></TR></TABLE>
I don't think Honda makes it, I remember hearing that its just a rebadged GM product, but Honda does sell it at their dealerships.
Old Apr 21, 2004 | 09:10 PM
  #34
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boltz &raquo;</TD></TR><TR><TD CLASS="quote">
it wouldnt matter because it goes through your fuel system.</TD></TR></TABLE>
the injectors are after the blower and manifold.
Old Apr 21, 2004 | 09:56 PM
  #35
mskibbz-T's Avatar
Don't you also put it into your oil system? Although JRSCs have self contained oil systems, huh...
Old Apr 21, 2004 | 10:24 PM
  #36
TRE_'s Avatar
Default Re: Sea Foam?? (mskibbz-T)
nice little writeup on how to use seafoam safley/correctly.: http://auto.snowsuperstars.com/seafoam.html
Old Apr 21, 2004 | 10:31 PM
  #37
ATS*Mark's Avatar
OG triple OG
Default Re: Sea Foam?? (THE_HX)
nice
im gonna buy this stuff when im about to change my oil
Old Apr 22, 2004 | 12:05 AM
  #38
BuddhaSiR's Avatar
Default Re: Sea Foam?? (Hella_JDM)
sea foam is like snapple. it's made from the best stuff on earth. This stuff works wonders. i have used it dozens of time through are motor vac machine at work. It just melts carbon away. cleans clogged injectors, O2sensors, combustion chambers.
Old Apr 22, 2004 | 02:12 AM
  #39
ATS*Mark's Avatar
OG triple OG
Default Re: Sea Foam?? (BuddhaSiR)
all this talk is making me giggle like a biatch i cant wait to try this stuff
Old Apr 22, 2004 | 01:38 PM
  #40
-Trinitron-'s Avatar
It's 100% Petroleum...I don't see how it could "hurt" anything...
Old Apr 22, 2004 | 01:49 PM
  #41
Boltz's Avatar
the injectors are after the blower and manifold.</TD></TR></TABLE>
I know that. It was stated earlier in this post that people with turbo cars have ran seafoam without problems, so why would it be any different than than on a JRSC if the injectors come after the blower?? It wouldnt, so why would it do any damage to the blower?.......
(i dont know too much about superchargers) But I doubt under vacuum that fuel would manage to back track into the manifold very far (dont know about JRSC manifold design either ) but that just doesnt make any sense...
I think it should be perfectly fine for the JRSC'd cars
Old Apr 22, 2004 | 03:11 PM
  #42
maxim's Avatar
I think the only worry SC'd owners had originally was the method of sucking sea foam through the vacuum lines. I don't see how the injectors would effect the SC.
Old Apr 22, 2004 | 03:35 PM
  #43
Blue-Civic-Hybrid's Avatar
Loved
Default Re: Sea Foam?? (maxim)
I'll be buying this stuff right before i do my oil change....
Old Apr 22, 2004 | 03:58 PM
  #44
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxim &raquo;</TD></TR><TR><TD CLASS="quote">I think the only worry SC'd owners had originally was the method of sucking sea foam through the vacuum lines. I don't see how the injectors would effect the SC.</TD></TR></TABLE>
exactly. theres no way the fuel would be "sucked back into the manifold" because the vacuum comes from the motor in the first place. i was originally referring to the brake booster line method causing potential hazards.
Old Apr 22, 2004 | 05:26 PM
  #45
ExVtec's Avatar
I ran it the other day on my turbo setup. Seemed like it ran great....I was impressed.
Old Apr 22, 2004 | 05:28 PM
  #46
ATS*Mark's Avatar
OG triple OG
Default Re: Sea Foam?? (ExVtec)
did you change your oil and plugs right after you did it?
Old Apr 22, 2004 | 06:45 PM
  #47
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">as I've stated, I just drive my car in the ocean.</TD></TR></TABLE>
LOL
does it matter if you just dump the whole can in the gas tank?
is there an advantage to doing like 1/3 gas tank and the rest in vac?
Old Apr 23, 2004 | 10:03 AM
  #48
maxim's Avatar
Default Re: Sea Foam?? (-iLLuZioN-B18C1)
No, I just did that because I had one can and as too damn lazy to drive up to the auto parts store for another can. I've seen others use one full can(1/3 in gas tank and 2/3 through vac), so I did the same thing. Worked like a charm getting the carbon off the piston tops.
Old Apr 23, 2004 | 10:37 AM
  #49
keebler65's Avatar
is it save to drive your car in boost when this stuff is in your gas tank? or will it reduce my octane rating?
Old Apr 23, 2004 | 04:52 PM
  #50
maxim's Avatar
dunno, it wouldn't hurt you to stay out of boost for a few days would it?
