SC61 efficiency range?
Old Jan 28, 2004 | 09:02 AM
  #26
legendboy's Avatar
Default Re: SC61 efficiency range? (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">
The most correct information in this thread.
Let me add something too. I spoke to a Garrett employee who is on HT. He told me that there is alot of misinformation on this site and this tread is proof. I wish you would post Brian.
art</TD></TR></TABLE>
I hope he posts too. It would be nice to have a real garrett athority on h-t, someone who actually works for garrett
Old Jan 28, 2004 | 09:45 AM
  #27
DIRep972's Avatar
Smarter than you
Default Re: SC61 efficiency range? (Enthalpy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enthalpy &raquo;</TD></TR><TR><TD CLASS="quote">Not true. there is a variant of the GT30R that uses the 82mm / 56trim GT40 Compressor. but mated to the true GT30R turbine wheel - 60mm, 84 trim. as opposed to the 68mm, 84 trim turbine of the GT35R. i have one good post though art. I have agree that there is alot of misinformation around about the new turbos. i scan probably 3-4 different web boards a day lookign for posts about this stuff so i can keep peopel straight!</TD></TR></TABLE>
oh yeh, I forgot about that combination... I still have your dyno vid on my comp.
Old Jan 28, 2004 | 09:47 AM
  #28
DIRep972's Avatar
Smarter than you
Default Re: SC61 efficiency range? (st00pid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by st00pid &raquo;</TD></TR><TR><TD CLASS="quote">Maybe if I learned to read the compressor maps I could build fast cars?</TD></TR></TABLE>
lol. building a car on the computer makes things alot harder then it is in real life.
Old Jan 28, 2004 | 11:15 AM
  #29
SiRkid's Avatar
Default Re: SC61 efficiency range? (DIRep972)
w3rd.
whose this brain guy art speaks of?
have him come forth immediately and post the correct info!
Old Feb 20, 2005 | 08:09 PM
  #30
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">THE 2ND MAP IS THE CORRECT MAP!!!!!!!!
I guess if you think about it there is no dead on map for a standard SC61. (since the compressor map for the wheel it uses is set up for the .70ar housing) But still, your best bet is to go by the .70ar map, compressor maps don't tell the whole story anyways.. It will get you close enough.</TD></TR></TABLE>
Correct, truly the point that should be learned here. But notice, no turbine map to match.
Recently there have been some specific SC61 maps available. I'll see if I can be able to post it up one day.
Old Feb 21, 2005 | 06:37 AM
  #31
Importracer_001's Avatar
Default Re: SC61 efficiency range? (TheShodan)
ok guys could you tell me whats the efficiency range of the SC61 with a S housing
on a stock bore B16
I dont know how to read compressor maps yet.
Old Feb 21, 2005 | 06:53 AM
  #32
JDogg's Avatar
Default Re: SC61 efficiency range? (Importracer_001)
sc61 will work on all sorts of stuff... from big motors with 30psi to small ones with 8psi.
just know you will have to rev it to keep it in boost. compressor maps dont really show the whole story, i have found you are much more likley to run the turbine out of efficency long before the compressor.
AndyFloyd
Sep 16, 2006 01:30 PM
Bad-T
Aug 18, 2004 10:27 AM
GT61 this 1.8t
Jun 17, 2004 04:01 PM
88CRXHybrid
Dec 28, 2003 12:46 PM
DSF
Feb 18, 2002 01:43 PM
