sc61 .63 a/r full boost???
Old Sep 14, 2003 | 06:33 AM
jmal1919's Avatar
Default sc61 .63 a/r full boost???
Did a search and didn't find much for the 2.3 f23 engine
my question is with a 2 1/2 diameter from the downpipe back through the muffler, at which rpm would a sc61 with a .63 a/r reach full boost? I'm lookng for a combination which will give me full boost at about 3600 or so, so if that would not be the right a/r or turbo, I'd like to hear that too.
thanks
Old Sep 14, 2003 | 07:27 AM
jmal1919's Avatar
bump
Old Sep 14, 2003 | 04:03 PM
jmal1919's Avatar
I know that noone can give a definite yes, but guesses/experience would be nice?
Old Sep 14, 2003 | 04:43 PM
Tinker219's Avatar
Default Re: (jmal1919)
itll pry be a little higher then that, maybe 4k. open up the DP/exhaust a lil bit, and you might see a lil sooner...
Old Sep 14, 2003 | 04:47 PM
jmal1919's Avatar
think I should go with a smaller a/r would help since I can't go with a 3" dp and keep ac
since I red line at 6k, looking to reach full boost at around 3600 or so.
Old Sep 14, 2003 | 06:05 PM
g2turbo's Avatar
just think about when it does reach full boost... hang the **** on
this is a theoretical question and nobody has a correct answer. try it and let us know
Old Sep 16, 2003 | 02:19 PM
Cyphear's Avatar
Default Re: (g2turbo)
I know this will spool between 4,800 and 5,000 on a 1.8 liter... so if I had to guess i'd say maybe 4,300.
Old Sep 16, 2003 | 02:30 PM
Bloodline's Avatar
I would suggest going smaller than a .63 on the hot side. You may run into surge problems with a compressor that large mated to that tiny turbine housing.
jeff
Old Sep 18, 2003 | 04:49 PM
jmal1919's Avatar
Default Re: (Bloodline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bloodline &raquo;</TD></TR><TR><TD CLASS="quote">
jeff</TD></TR></TABLE>
say that again? Do you mean that I should "not" go smaller....
Old Sep 18, 2003 | 06:35 PM
NuclearB18B's Avatar
i see full boost (.45 bar) right at about 5000 on a stock b18b with 2.5 inch dp.
Big Wood
Jan 7, 2006 04:25 PM
honkey2fly
May 15, 2004 10:32 AM
Hoodwinked
Sep 2, 2003 06:37 PM
Doogie Howser
Jul 27, 2002 10:09 AM
Integra187
Sep 21, 2001 07:13 PM
