SC-61 with InlinePro.....
Old Feb 9, 2005 | 08:01 AM
b18Gooch's Avatar
Default SC-61 with InlinePro.....
I have an InlinePro Manifold and a SC-61. Is it necessary to use a gasket between the manifold and the turbo? I have heard that you don't need one, and I have heard that you must have one. If I should use a gasket, what material is best to use for a gasket?
Thanks in advance!
Kevin
Old Feb 9, 2005 | 08:05 AM
b18bturbo's Avatar
Default Re: SC-61 with InlinePro..... (b18Jay)
you dont need a gasket just make sure the surfaces are true and machiend flat
Old Feb 9, 2005 | 08:15 AM
SPOOLINmatt's Avatar
Default Re: SC-61 with InlinePro..... (b18bturbo)
i never used a gasket but im going to go ahead and put it in there this time around....or should i not?
Old Feb 9, 2005 | 08:37 AM
g2turbo's Avatar
Default Re: SC-61 with InlinePro..... (SP00LIN)
I would not use the gasket unless you want to take it back apart when it starts to leak. Same with your wastegate... the gasket is not needed.
Old Feb 9, 2005 | 12:56 PM
b18Gooch's Avatar
Thanks for all the quick replys!
journeyquest
Sep 3, 2010 12:39 AM
hondaeg8
May 31, 2006 12:56 AM
VtecAdil
Oct 16, 2004 09:40 PM
1.8T_EG
Sep 12, 2003 07:00 PM
Btothe3rdDegree
Aug 20, 2003 06:26 PM
