safe to turbo?
Old Jul 17, 2008 | 07:46 PM
GEOz2k7's Avatar
Default safe to turbo?
How reliable can this be? i just did my timing belt, and head gasket water pump, and a couple other things, new clutch. How reliable and safe will i be to boost 7psi on a t3 turbo?
Old Jul 17, 2008 | 07:56 PM
inspector01's Avatar
What motor and that?? It will be fine if it runs good, has a solid timing belt, and headgasket. You could run forever on that with no problems if done correctly.
Old Jul 17, 2008 | 08:41 PM
94delslo's Avatar
Default Re: (inspector01)
Your engine will be safe/reliable with a turbo ONLY if you get your car tuned by a competent tuner. Using quality parts does play a role in how reliable everything is going to be also. Keep those things in mind and you will be good.
Old Jul 17, 2008 | 10:09 PM
GEOz2k7's Avatar
Default Re: (94delslo)
well i have a garrett turbo. and its a little bit like a t3. the manifold is a good one i was told by my friend who owns a shop. and the down pipe i am gonna get custom made. my motor is a ls b18b and i am stilll wanting to know what parts i need. i have the oil return line. and the intercooler was custom pieced together but i think i am gonna buy a new one. I have been going back and forth between ls vtec and ls turbo. i cant make up my mind.
Old Jul 18, 2008 | 05:38 AM
chimmike's Avatar
Default Re: (GEOz2k7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GEOz2k7 &raquo;</TD></TR><TR><TD CLASS="quote"> manifold is a good one i was told by my friend who owns a shop. .............i am stilll wanting to know what parts i need. i </TD></TR></TABLE>
so your friend who owns a shop and seems to know about turbo manifolds can't tell you everything you need for a complete turbo setup?
omgwtfbbqcrx
15
Nov 28, 2006 10:33 PM
Scotty Dosent Know
Aug 2, 2006 05:04 PM
boostaholic
Nov 11, 2004 02:37 PM
pane93civhb
Oct 17, 2004 07:10 AM
buckfittyone
Sep 5, 2003 11:02 PM
