60-1 turbo, stock B18B (LS) and good tuning, dyno inside
A lot of people have been asking me about using a 60-1 turbo on stock motors. I wasn't originally planning on boosting my LS motor since it was a backup motor until i finished building my B16, but i can't stand being NA. The turbo i'm using is an Innovative Turbo Systems t3/60-1, .63 a/r turbine, .70 a/r compressor, stage 5 wheel. Turbo makes really good power even on an absolutely stock LS motor as you can see. After looking at my datalogs, i get 1psi boost at 3300rpm and 12psi by 5k which isn't bad at all considering the size of the turbo. Torque is incredible and it pulls like a freight train after 4000rpm. This pull was on .8 bar (~12psi) and pump gas. Max power was 278whp, but we played with timing a little and were able to pick up .5 ft-lb of torque w/ 1 degree less total timing on the top end so i was content with that. With some C116 and a better intake manifold, i plan on pushing 300+whp. I'm using a Speed Pro engine management for tuning. Thanks go out to Alex (GSRev) for coming out to the dyno and lending me a hand, and Lawrence of Conley Racing for the best tuning i've seen.
ITS 60-1 @ .8bar (~12psi)
Bone stock B18B (LS)
550cc injectors
Speed Pro ECU
Pump gas
Chris
[Modified by boostaholic, 9:06 PM 10/23/2002]
550cc injectors
Speed Pro ECU
Pump gas
Chris
Re: 60-1 turbo, stock B18B (LS) and good tuning, dyno inside (boostaholic)
Congrats on one of the cleanest looking si's I have seen. Very nice setup! And always glad to help!
Smarter than you
how much timing retard were u running per psi?
#'s look very similar to mine. but u made more power on a little less boost. i was running like 12.7psi or around .87bar. you had a 500rpm's more lag though. we will have to keep in touch I have been interested in the 60-1 lately and im looking forward to eyeing your project.
good job
chris
good job
chris
confused
Can some one explain to me why boostaholic made 277whp and 241 lb-ft torque on 12 lbs on a ls, but Arturbo made 277whp and 200 lb-ft torque on only 7 lbs?
Re: confused (flip1199)
HP= (TQ * RPM)/ (5252)
I think Arturbo is running a GSR motor so the VTEC head helps in the higher RPM's. Notice how the torque curve falls off on the LS, because the head can't breathe well at higher RPM's in stock form.
damn dude thats awsome.... I thought my turbo was big and laggy ,but your is bigger and more laggy..
Re: 60-1 turbo, stock B18B (DIRep972)
I'm running about .7 degrees retard per psi up to 12psi and 7500rpm. I'll datalog some runs to see where my max duty cycle is. I'm want to say it'll be around 70%. I've been pondering the thought of doing some porting on another LS head, throwing in some crower valve springs and turbo cams to see if i can't get 310+whp out of this thing on the stock bottom end on pump gas at or around the same boost level with a higher redline. If i can keep the torque up there after 6k i should be able to hit that.
[Modified by boostaholic, 4:14 AM 10/24/2002]
Re: 60-1 turbo, stock B18B (TurboDANDEE)
nice numbers... u got pics of ur car and set up? what is ur A/F set on?
[Modified by boostaholic, 7:13 AM 10/24/2002]
Re: 60-1 turbo, stock B18B (turbo Si)
I picked up my car from Connley the night before. I wanted to go but had to work!
Location: California ... Beauuutiful, so cal, pwnited States
Re: 60-1 turbo, stock B18B (SiRkid)
awesome numbers, i just ordered my t3/60-1 with a .82 turbine for my fully built h23. This is going to be fun.
Re: 60-1 turbo, stock B18B (PreIudeSI)
Very nice!! Thats the difference between a small turbo and a big turbo.. however when you run lots of boost the torque is insane..
Stock LS @ 20 Psi with T3/T04B:
jason
jason
