Saab injectors
Old Mar 4, 2003 | 12:09 PM
Tinker219's Avatar
Default Saab injectors
I have access to literally TONS of Saab injectors. Anybody know what size they are?
Old Mar 4, 2003 | 12:10 PM
technine's Avatar
Default Re: Saab injectors (Tinker219)
I don't know the size, but I have a local yard that has tons of saabs and Volvos and I would also like to know. And do they fit our cars? Are the saturated or peak hold types?
Old Mar 4, 2003 | 12:11 PM
b18bturbo's Avatar
Default Re: Saab injectors (technine)
they are 340cc injectors bosch made 34lb hr.
here are there part numbers if you care
Fuel Injector
C1000-12973
[Modified by b18bturbo, 3:13 PM 3/4/2003]
Old Mar 4, 2003 | 12:13 PM
Tinker219's Avatar
Default Re: Saab injectors (b18bturbo)
cool...thanx V...I think I will be getting some for my gfs del sol(d16)....
Old Mar 4, 2003 | 12:16 PM
b18bturbo's Avatar
also resistance is 11-18 ohm on those injectors which are direct fit for ours cars without resistor boxs.
Only prob you might have is the upperportion of the injector it might need to be grinded since is bosch style
[Modified by b18bturbo, 3:16 PM 3/4/2003]
Old Mar 4, 2003 | 12:20 PM
Tinker219's Avatar
ya....boostinLS(i think) converted a set of injectors over by modifying the upper half of the injectors in this manner.
Old Mar 4, 2003 | 12:22 PM
b18bturbo's Avatar
we either drill the rail which is the easiest and simplest if you have drill press so you can make a clean cut.
Old Mar 4, 2003 | 12:24 PM
Tinker219's Avatar
oh ya...drill it out so the plastic insulator thing goes inside the rail correct?
I will probably do this...
Old Mar 4, 2003 | 12:26 PM
b18bturbo's Avatar
yup but remember you do that you never can go back its hard as hell to do that. then you need a really really fat oring
Old Mar 4, 2003 | 12:33 PM
Tinker219's Avatar
or lots of mega-copper
its the stock rail, so if she has to go back, itll be with a GE or osmething nice like that....
shes running 10psi max, so ya...
blkb18
May 18, 2008 05:42 PM
move_right
Dec 22, 2002 07:45 AM
int3gra
Apr 28, 2002 09:25 AM
