S368 BW Bullseye w/ Race Cover
Anyone have some good info on power/spool charecteristics of this turbo? Setup is a built 2.0 with PRo 1's and P&P head with Twinscroll top mount...i want to see low boost numbers also. Sorry but could not find anything specific to what i am looking for on the search engine.
THANKS!
THANKS!
Re: S368 BW Bullseye w/ Race Cover
very good turbo. i'm running the s362 with a ramhorn on a built type r stock bore and works very well. i like it alot..! I'm really into all the Borgwarner turbos. your setup with that turbo should make some crazy power.!!
All the stuff I've seen the s368 spooled about the same as a s372 and of course made less power. Wade's s372r made 17lbs by 5300 rpm.
Oh really, I thought you were the one asking the questions? I find it hilarious you say no way, like that's not even possible or maybe you just don't want to believe it? The reason it makes sense to everyone but you is because the s368 and the s366xl were class specific turbochargers with THE SAME TURBINE as a s372. There would be minimal if any difference in spool with the only the inducer of the s372 compressor wheel being larger and the fact it's larger means it will be making more power at same rpm level even if the pressure ratio's are different.
Moderator
366 spools a TON faster than the 368. the 368 has very similar spool characteristics to the 372. we made 810 on a 368 with boost in the upper 30's. if we need more turbo than a 366, we usually just jump into a 372.
The reason i say NO WAY is because after 20minutes on the phone BullsEye recommended this turbo over the S372 becasue it would make similar power but would provide quicker spool...if you are CORRECT than i should have just gone with the S366...
WHAT IS THE DIFFERENCE? THEY CANNOT BE IDENTICAL?
My mistake was not looking into it more in detail...if there is a HUGE difference in spool from the S366 to the S368 than i thought the same would apply to the 372...i will check with Bullseye and follow up with some data...i hope i didnt go to big. I was wanting 750whp with a decent spool.
The difference is the size of the inducer on the compressor.
The t4 regular s366 will spool much faster and will definitely support 750whp.
Turbo part#
Compressor Wheel Turbine Wheel
Ind. Exd. Trim Ind. Exd. Trim
300100-1 62mm 84.6mm 54 76.3mm 67.6mm 79
300100-2 62mm 84.6mm 54 76.1mm 66.7mm 77
300100-3 66mm 92.7mm 51 76.3mm 67.7mm 79
300100-4 66mm 92.7mm 51 76.1mm 66.7mm 77
300100-5 68mm 101.9mm 45 83.4mm 74.3mm 79
300100-6 70mm 101.9mm 47 83.4mm 74.3mm 79
30010- 7 71.8mm 101.9mm 50 80mm 73.4mm 84
300100-8 71.8mm 101.9mm 50 83.4mm 74.3mm 79
300100-9 71.8mm 101.9mm 50 95.8mm 88mm 84
So there is a 2mm difference between the S366 and the 368? And there is a HUGE difference in spool?
Why then with the s368 to the s372 there is a 4mm differece but the spool is almost the same? Sorry help me understand...be harsh i dont care! I am not the sensitive type! LOL just want to learn!
S372 BELOW
S372 BELOW
POwer goal is 750whp i was just hoping to make it there with out pushing the turbo hard...so i went with the s368 thinking the spool would not be as bad when compared to the s366...i understand how it would be night and day diff between the 362 and 368.
Im not looking for "low end power" just a fatter powerband...dont want to have to shift at 10k evry f'n gear to stay in the sweet spot...you know? I was hoping max 9200-9500. Dont want to abuse my motor that much...I was hopin full boost at like 6200rpm? Am i asking to much out of this size of a turbo?
Notice how there's 3 turbine options for the 72mm turbos, the one MOST everyone uses is the 83.4mm one, which is the same as the s368 and the s366xl(which isn't on your chart). The regular s366 is 7mm smaller which is pretty significant on the turbine whereas the compressor inducer is only 2mm smaller than the s368.
