s300 launch control (2-step)
i was wondering which was better for the launch control in the hondata s300. fuel only cut or fuel + ignition cut.. which is better and why.. or does it even matter?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airshifter »</TD></TR><TR><TD CLASS="quote">launch control only has fuel cut from my experience with the ability to alter the timing, but the main rev limiter has fuel plus ignition</TD></TR></TABLE>
no launch control can use fuel+igntion also. i tried it.
just wondering which is better and why? one more harmful than the other? or does it even matter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by glosssilver »</TD></TR><TR><TD CLASS="quote">add fuel cut ignition will help build boost at the line but it will heat up the motor quick.
i have my set at 7500 rpm with +10 on fuel and -10 on ign it work great</TD></TR></TABLE>
what turbo are u running and how much boost r u getting @ the line ??
this is on the s300 right...
for the rev limiter it has an option for fuel or fuel + ignition... for the 2-step you can add fuel and retard timing there really isnt an options, you either plug in a number or you dont... but on the subject of the rev limiters, which of the two choices do you guys use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94whtgsr »</TD></TR><TR><TD CLASS="quote">for the rev limiter it has an option for fuel or fuel + ignition... for the 2-step you can add fuel and retard timing there really isnt an options, you either plug in a number or you dont... but on the subject of the rev limiters, which of the two choices do you guys use?</TD></TR></TABLE>
the option for the rev limiter (fuel or fuel+ignition) affect the launch control rev limiter also. so like i said three times already the 2step can be either fuel or fuel+ignition cut. which is better or more harmful?
ZebrasoHD
Engine Management and Tuning
Sep 29, 2018 06:37 AM
teamjdm239
12
Mar 21, 2010 07:40 PM
Pippen_001
Jul 26, 2007 01:24 PM
