s200b: CEL and Shift light come on?
Old Jun 10, 2005 | 09:43 AM
B00STED Si's Avatar
Default s200b: CEL and Shift light come on?
ever since i got the car tuned last week, i noticed that sometimes, maybe once or twice a day, out of no where the CEL and shift light come on and stay solid, like its in limp mode, but its not, i still can rev to w/e i want and everything seems the same. also, the L.E.D. on the s200b box itself stays solid red, indicating there are no trouble codes.....then ill turn off the car, start it back up and the shift and CEL wont come on again like that for the rest of the day, then it'll happen the next day. what could be causing this??? could it be from when the tuner was taking out the eprom and messing around with the ecu or s200b??
THEN, when it happened today i pulled over and pulled around with the wires to make sure they were all tight, and nothing was loose, i was wiggling around the interface cable and then it started flashing two different codes??? when i'd wiggle it different ways it would flash two different codes, 1 flash and then 4 flashes. (1- #1 o2 sensor, 4 - Crank position sensor) . so i was like well if these are actually trouble codes, then they'll flash when i restart the car again. so i shut off the car, restart it, no damn lights come on. any advice people?? i talked to one of the hondata techs and he didnt seem to have a good answer...
Old Jun 10, 2005 | 02:05 PM
B00STED Si's Avatar
Default Re: s200b: CEL and Shift light come on? (B00STED Si)
BUMP. PLEASE HELP!!
Old Jun 10, 2005 | 02:12 PM
dustin's Avatar
know any friends with a hondata box? try theirs.
Old Jun 11, 2005 | 03:00 AM
B00STED Si's Avatar
Default Re: s200b: CEL and Shift light come on? (dustin)
no, but ill check around. it seems weird tho that it only started happening after i got it tuned.
Old Jun 11, 2005 | 05:06 AM
B00STED Si's Avatar
anyone else??? any hondata tuners wanna chime in???
Old Jun 12, 2005 | 05:59 AM
B00STED Si's Avatar
bump
Jap.Doe
Jul 2, 2012 04:06 PM
fishinfool88
Dec 8, 2008 07:48 AM
O16581724 5 2 5
10
Nov 7, 2005 07:10 PM
yellowEG
86
Jan 14, 2005 01:25 PM
