s cover vs. e cover
Old Mar 7, 2005 | 07:32 PM
JDogg's Avatar
Default s cover vs. e cover
any gains by using the bigger compressor cover? assuming they ahve the same a/r
Old Mar 7, 2005 | 08:37 PM
june's Avatar
Default Re: s cover vs. e cover (JDogg)
I would also like to know. Since I have a S cover t4 SC61.
Old Mar 7, 2005 | 09:18 PM
BoOsTiN Dc2's Avatar
Default Re: s cover vs. e cover (june)
bump
Old Mar 7, 2005 | 09:28 PM
ScottEK's Avatar
Default Re: s cover vs. e cover (tRaCeBuStAbUsTeR)
also would like to know.
Old Mar 7, 2005 | 10:10 PM
Def's Avatar
Def
Default Re: s cover vs. e cover (ScottEK)
From everything I've seen - it just depends on the wheel in there. Some wheels will like the S cover, while some will like the E cover more.
I know the 60-1 wheel is slightly more efficient in the E cover versus the S cover.
Old Mar 7, 2005 | 10:28 PM
Arturbo's Avatar
Better than steak
25 Year Member
E and S have a different A/R so how can they stay the same? Or are you talking about the turbine housing?
Old Mar 7, 2005 | 10:30 PM
Maveric's Avatar
Default Re: s cover vs. e cover (Arturbo)
i beleive they are talking about the housing....imo the main reson people would go w/a smaller housing is for size/spacing issues.....I would assume the larger housing is going to flow more
Old Mar 7, 2005 | 11:35 PM
DefiantGSR's Avatar
Default Re: s cover vs. e cover (maveric)
I believe there is a loss of efficiency when going from a .60E housing to a .70S housing.
Old Mar 7, 2005 | 11:56 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: s cover vs. e cover (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR &raquo;</TD></TR><TR><TD CLASS="quote">I believe there is a loss of efficiency when going from a .60E housing to a .70S housing.</TD></TR></TABLE>
I've heard the other way around but I have not seen proof of this.
Ive seen same hp on set ups that are the same, but Ive never seen a back to back test done. hmm, this could be something to test on the engine dyno.
Old Mar 8, 2005 | 12:29 AM
hpfsi's Avatar
Saw this in another thread....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rod Short &raquo;</TD></TR><TR><TD CLASS="quote">
The SC63 is actually more expensive than the SC61, but not a lot more powerful. We rate the SC63 at 700-hp, which is only twenty more than the biggest SC61. By the time you add an S style compressor cover (4" inlet / 2.5" outlet), you already picked up 10 to 15 hp, which would put you just about there. The SC61 has a much more efficient compressor wheel.</TD></TR></TABLE>
That goes along with what I've always heard about larger a/r comp housings.
Old Mar 8, 2005 | 05:46 AM
JDogg's Avatar
Default Re: s cover vs. e cover (hpfsi)
hmm.. well we have access to and e and s cover for the gt3071r.. we might just have to test this out one day..
Old Mar 10, 2005 | 10:59 AM
hpfsi's Avatar
sounds good, if you have the time give it a shot - we'd all be interested in the results
spoolinvtec54
Jul 5, 2011 05:31 PM
1.8tgsr
Feb 11, 2005 07:26 AM
turboex
Jun 15, 2004 10:30 PM
