rx7 injectors..?
Just wondering if anyone has used JDM 89-91 FC turbo (rx7) injectors.. They are the same impedance as my stock .(99 type-R) injectors.. They are 550cc and they fit the rail perfectly with the shorter grommets. My question is if they are the same impedance, does that mean they are the same type. .( saturated ) and will work without electrical modification. .? Iam running a stand alone so controlling them is not a problem.
put a multimeter across them. If you see about 11-12ohms of resistance you have saturated injectors. if you see less than 4ohms you have peak and hold, and you will need a resistor box to controll those bad boys.
Schister66
Apr 26, 2006 08:36 AM
boost_is_best
Feb 28, 2006 03:45 PM
Unknwn_1
Feb 11, 2003 10:09 AM
