Running Velocity stack, need filter options
Old Oct 31, 2006 | 11:14 AM
bb_one's Avatar
Default Running Velocity stack, need filter options
I am currently running a 4" inlet Velocity stack that is 8.5" in total diameter. I am looking for a filter that might be able to fit over the stack, but I seriously doubt I will be able to find one.
Just posting here incase someone might know of a company that makes one. K&N does not and the search did not yield any results.
Any help would be greatly appreciated, thank you.
Old Oct 31, 2006 | 12:45 PM
TurboCoop's Avatar
Default Re: Running Velocity stack, need filter options (bb_one)
I put mine in an airbox but it only has a 5" diameter at the big inlet part... it would be hard to fit yours in one
Old Oct 31, 2006 | 02:43 PM
reuben's Avatar
I have the same velocity stack 8.5'' total diameter, I just got a screen and riveted it onto the velocity stack.
Old Oct 31, 2006 | 10:15 PM
bb_one's Avatar
Default Re: (reuben)
Hmm the airbox idea sounds very interesting. Would you happen to have any pictures?
I don't think that's a viable option for me as I have limited space as is. I was hoping to luck out and a miracle to happen and find a round tapered 8.5" filter.
I thought about the screen, but that would really negate the reasoning behind running the velocity stack. I just don't feel right running the thing open, but it sure does feel/sound/spool badass.
Old Nov 1, 2006 | 04:46 AM
TurboCoop's Avatar
Default Re: (bb_one)
Mine actually sounds exactly the same with the airbox, maybe a little quieter. I have some pics I have to upload I just took em cause I just finished the damn thing monday. I think putting a screen in a velocity stack would disrupt the airflow too much but Ive seen people that have it.
Old Nov 1, 2006 | 07:45 AM
bb_one's Avatar
Default Re: (TurboCoop)
Yea that is why it's either filter or open. But your airbox idea has got me thinking. Pictures would be awesome.
Old Nov 1, 2006 | 09:50 AM
Dc4turbo408's Avatar
Velocity stack actually helps?
Old Nov 1, 2006 | 10:12 AM
TurboCoop's Avatar
I used 22 guage steel sheet metal and riveted it together, and got 2 K&N filters from the auto parts store and siliconed them in. The velocity stack is 2 3/4" at the small side and like 5" at the big end, which is inside the box you cant really see it though. It looks nice and my turbo is finally getting clean air...
Old Nov 1, 2006 | 01:46 PM
whiteef8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop &raquo;</TD></TR><TR><TD CLASS="quote">I used 22 guage steel sheet metal and riveted it together, and got 2 K&N filters from the auto parts store and siliconed them in. The velocity stack is 2 3/4" at the small side and like 5" at the big end, which is inside the box you cant really see it though. It looks nice and my turbo is finally getting clean air...
sweet setup mang. airbox is a really good idea, i've read everywhere that the more surface area the better, that must be very effective!!
Old Nov 1, 2006 | 02:12 PM
bb_one's Avatar
Default Re: (whiteef8)
I like the setup. I will look into it.
My problem however is limited space. My velocity stack is 8.5" in diameter and it is about 3-4" away from my frame.
Old Nov 1, 2006 | 04:56 PM
TurboCoop's Avatar
why dont you just do something like this, find the filter with the biggest base you can- I know ones for F-150s are pretty big and they have them at advance auto parts. Measure it and cut the and of the velocity stack that big, then weld on a little peice to extend it out and have a place to put a screw clamp on there like in the pic
Old Nov 2, 2006 | 05:49 AM
bb_one's Avatar
So far the biggest base I can find is 6". If I cut the velocity stack down to that size, it would negate the affects of the velocity stack.
I think the best idea so far is the air box.
Old Nov 2, 2006 | 02:16 PM
tepid1's Avatar
where did you get the velocity stack?
Old Nov 2, 2006 | 04:50 PM
bb_one's Avatar
Default Re: Running Velocity stack, need filter options (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">where did you get the velocity stack?</TD></TR></TABLE>
Turbonetics
Old Nov 3, 2006 | 05:47 AM
reuben's Avatar
i like the idea of the airbox as well, but I dont have that much space either. But the drawing/scheme above seems a little more possible.....
Old Nov 3, 2006 | 05:54 AM
reuben's Avatar
also found this stuff, but it doesnt say the exact size on the face on one, and the other is only 8inches.
http://knfilters.com/search/pr...-4165
http://knfilters.com/search/pr...-4131
I'm going to see if I could find anyone in my area that has those in stock....
Old Nov 3, 2006 | 06:03 AM
b18sihatch's Avatar
Old Dec 28, 2006 | 12:21 PM
JDM_WHR's Avatar
what size is the outlet? I might get one to put on the end of my AEM V2.
Old Dec 29, 2006 | 01:03 PM
bb_one's Avatar
Default Re: Running Velocity stack, need filter options (JDM_WHR)
Well I have seen 2 sizes for the outlet, 3" or 4". My 60-1 has a ported shroud so the turbo inlet is 4".
Gsrsi
Dec 7, 2011 11:05 PM
hondamn1320
Feb 28, 2008 05:10 AM
hamadiscool
Nov 5, 2006 10:09 PM
slvrstns2000
Jun 7, 2006 09:25 AM
400WHPITR
Mar 16, 2003 11:49 PM
