Running Uberdata, car started running lean all of a sudden partial throttle why?
Old Apr 26, 2005 | 01:57 PM
  #26
sean's Avatar
Default Re: Running Uberdata, car started running lean all of a sudden partial throttle why? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
bigwig and a couple other guys have been working on a fix so closed loop will disable upon map signal rather than map + tps. It sounds like they have gotten it working pretty well right now. This should help for a smoother transition into boost i would think.
Oh and i'm also having a similar problem on a guy's car i'm tuning. The car would run fine one minute and then the next minute it would be bucking all over the place at wot after like 4k rpms. I tried adding and subtracting fuel with no luck. It would even do it when the afr read alright. Then sometimes when it would happen the afr would jump all around. I think its a wiring issue because i used to have an afc wired in there before we put uberdata in. </TD></TR></TABLE>
hehe big wig is the one who tuned my car. picking up that new chip from him tonight.
Old Apr 26, 2005 | 02:08 PM
  #27
Burke's Avatar
Banned
Default Re: Running Uberdata, car started running lean all of a sudden partial throttle why? (sean)
mine did that **** this weekend. just the map sensor being loose on me
Old Apr 26, 2005 | 03:55 PM
  #28
B16Civic93's Avatar
Default Re: Running Uberdata, car started running lean all of a sudden partial throttle why? (B16Civic93)
bump it up
Old Apr 27, 2005 | 05:53 AM
  #29
B16Civic93's Avatar
bump for more help, i'm getting a chip sent to me with closed loop disabled it should be here friday and hopefully that will fix the problem. any other ideas on what it might be?
Old Apr 27, 2005 | 06:12 AM
  #30
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sean &raquo;</TD></TR><TR><TD CLASS="quote">hehe big wig is the one who tuned my car. picking up that new chip from him tonight.</TD></TR></TABLE>
haha nice
Old Apr 27, 2005 | 07:29 AM
  #31
sean's Avatar
closed loop is now disabled as is o2 heater. car does not studder at lower rpms now and it idles better then it did.
Old Apr 27, 2005 | 08:09 AM
  #32
EJ1 wilcox's Avatar
What are the advantages of running closed loop disabled?
Right now I have my closed loop enabled and my car seems to be running fine. Should I switch to open loop and tune part throttle? And why?
Old Apr 28, 2005 | 06:16 AM
  #33
SOHC_MShue's Avatar
Default Re: Running Uberdata, car started running lean all of a sudden partial throttle why? (EJ1 wilcox)
With closed loop disabled you can tune the mixture leaner than 14.7:1 for better gas mileage and you can ensure that you won't lean out in part throttle boost conditions.
Old Apr 28, 2005 | 06:19 AM
  #34
blackeg's Avatar
it can also negate the effects of an o2 sensor going bad, as in my case. in general, you have more control over the fuel values
Old Apr 28, 2005 | 07:13 AM
  #35
B16Civic93's Avatar
Default Re: Running Uberdata, car started running lean all of a sudden partial throttle why? (blackeg)
bump for more help
Old Apr 28, 2005 | 05:09 PM
  #36
B16Civic93's Avatar
got another chip in with closed loop disabled and it works great, thanks for the input guys. i'm glad it runs right again. its a little rich now. so i need to tune idle and partials but its better than it was. thanks again
booboo782
Engine Management and Tuning
Feb 3, 2014 06:28 PM
fatboy1185
32
Sep 23, 2008 07:37 AM
gt35rSI
Mar 29, 2008 08:25 PM
BoostedGSRBubble
Mar 8, 2003 10:21 PM
raene
Jul 17, 2001 12:32 PM
