38 or 44mm Tials?400WHP
Almost got everything i need for my build and was wondering, can i use the tial 38mm gate.I am going to be using a ramhorn mani with the gate in the middle of the collector(like Full-Race) and the turbo that is going to be used is a GT35R .63AR.
I dont want to have any spiking issues, but if there are people that have been using the 38 with success, I would like to hear about it.
Budgets getting tight and I can can the smaller gate for considerably cheaper.
Holla back, lol.
Holla back, lol.
Re: 38 or 44mm Tials?400WHP (93supercoupe)
This i know about wastegate selection.
Big turbo + Low boost = 44mm
Big turbo + High boost = 38mm
And dont go half or double the spring rate.
I dont know how well i can explain this but here it goes..
The wategate relieves pressure, if your running big turbo and low boost, it will have to relieve more pressure then at a higher boost, so more chances of spiking at lower boosts.. If the turbo is small, then its ok to run a smaller WG for low/high boost.
Hope that helps
Hope that helps
Re: 38 or 44mm Tials?400WHP (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">This i know about wastegate selection.
Hope that helps </TD></TR></TABLE>
Nicely put, I've seen some very high hp cars running the 38mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">And dont go half or double the spring rate.</TD></TR></TABLE>
And how would you go 1/2 the spring rate??????
Re: 38 or 44mm Tials?400WHP (tgreaves)
i built my own manifold with WG in the center of the collector. it would hold 18psi just fine (18psi spring) with a 35r and 38mm gate. made about 550whp. i dont like the 38mm wg's very much though
if you have the money get the 44mm. its worth it just for the v-band if nothing else.
Re: 38 or 44mm Tials?400WHP (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">if you have the money get the 44mm. its worth it just for the v-band if nothing else.</TD></TR></TABLE>
The v-band is nice.. I just love my 44mm TiAL..
That is the exact theory Ive been telling people, butI just wanted to make sure it was correct.
18psi on a 35R and u made 550?? Thats impressive, if possible.Myabe with the bigger exhaust housings.
I havent decided yet on which gate. 44's are the pimpness.
it was a T3 .63 with a ported shroud S cover...stock cylinder head with crower springs/retainers/cams. no port work. mani/dp/exhaust i made myself....all 3 inch exhaust work. made 616whp@25psi it would not make any more power even at 30psi.....so i just dropped the boost down to 25 and left it at that. 2wd dynojet on slicks.
the car went 10.20 running 18psi all the way down the track. and 10.0 running 18psi 1st 2nd and 3rd gear and 25psi in 4th. it had 9's in it but a dropped sleeve cut me short on that goal. the short times were great on that turbo. 330's is where the car shined
my last set up , I could not hold the boost low on a 40mm. Deff needed a bigger gate to run lowere boost.
I have a 44mm now and its pimp cuz of the vband option. lol
Im planning on running at least 1bar daily, so it should be ok.
Re: 38 or 44mm Tials?400WHP (PM-Performance)
whoa, 550@19. I made 490@19 on my gt35e. I guess that compressor housing does help. I just have the e cover, but i think i'll have to upgrade now.
Re: 38 or 44mm Tials?400WHP (seen4ever)
Wow, impressive numbers for such low boost.My goal was 400 whp and I was palnning to go as high as 20-22lbs.
Im doind stock B16 head and stock LS block w/ pistons and rods.
Aslong as its on pump, ill do what it takes to get 400.
I want the 44, but this build will go alot quicker if i just get the 38, or so it will seem.Maybe I will pass on buying the gate for now and focus more on other things.
Im such a ***** when it comes to deciding on parts.I just want to get what I want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">i'll trade you decisions! im debating between a 44mm or the HKS GT2. i know what i WANT....but im broke! </TD></TR></TABLE>
Go sell some parts to Vance to make money..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">haha! i think im all out of universal D series parts! unless he wants to put a 35R on it </TD></TR></TABLE>
I think hes going to build a B-series next.. Im going to steal his paint supply so we dont have a chevy orange honda block roaming around MIR..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">hahaha thank you! introduce him to mandrel bends too!</TD></TR></TABLE>
Good idea.. Im trying to explain to him about race fuels right now.. Nothing like me tuning his car for pump gas and he goes and puts some VP Import 120+ in it and got beat by a pocket rocket..
oh you mean that putting the most octane gas possible in doesnt make you fastest? damnit! maybe thats where ive been going wrong hahaha.
is he going to be making any aperances this year? did he give up on the D build?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">oh you mean that putting the most octane gas possible in doesnt make you fastest? damnit! maybe thats where ive been going wrong hahaha.
is he going to be making any aperances this year? did he give up on the D build?</TD></TR></TABLE>
Hes ashamed of it right now.. It made one track show this year.....*cough* 14.2 *cough*..
He rebuilt the D, I had to give him a block since he didnt think about honing a block 100 times and reusing the same pistons.. After about 15psi at 14+air/fuel the pistons would expand out enough for the knock to go away..
He just loves to hear about my stock sohc that ran 12's.. He is determined to make a showing this year, Just look for the big red matco tent..
cool sounds good...well if you guys are hitting up any of hte MIR nopi events....usually that friday night there is a big GTG here at the shop...you guys should come down!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">its all good in the hood.
Im going to go eat lucky charms anyways. </TD></TR></TABLE>
I really do feel bad about that, I totally forgot that this was your thread.. I sent you a PM with my suggestion to your question..
