Running lean
Old Jun 6, 2005 | 11:17 PM
b16turbosi's Avatar
Default Running lean
I am running very lean at 7psi on my b16, and sadly i have been for a while. I finally got the cash to purchase an s200w/boost, rc 550, fuel pump, etc. I know this will help my fuel problem, but how do i know what damaged has been caused by running so lean, and what damage is usually caused by running lean for a while. Any symptoms of certain problems. Thanks
Old Jun 6, 2005 | 11:20 PM
Dunc's Avatar
BCICAN
Default Re: Running lean (b16turbosi)
I believe you could just do a compression and leakdown test. If the results are fine, then you should be good to go. I'd do that before you tune, so you don't waste money on a tune (that's in case you need a rebuild).
CO_CReX
May 8, 2007 06:03 PM
H22CL
Jun 20, 2004 11:11 AM
jeremy.
Sep 27, 2003 02:12 PM
1.8T_EG
Oct 27, 2002 07:11 AM
4doorH22
Apr 15, 2002 06:43 PM
