running the heater .....
Old Mar 24, 2002 | 11:28 PM
Cyber ITR's Avatar
Default running the heater .....
does running heater helps preventing detonation ???
thanks
Old Mar 24, 2002 | 11:38 PM
VaporTrail's Avatar
New User
Default Re: running the heater ..... (VTEC_SiR)
nope. Running the heater does little to help the car run cooler.
Old Mar 25, 2002 | 08:00 AM
92HB_HB's Avatar
Default Re: running the heater ..... (VaporTrail)
actually, running the heater while idling to cool down does help cool the engine cool faster because the heat absorbed by the coolant from the engine is being dissipated into the heater core which is like a 2nd radiator. but i dont thinke it would help you when you're driving hard and hoping for the heater to help cool the car with a noticable difference. i had a problem with my car over heating on the highway last year, but when i turned on the heater full blast, my engine temps dropped back to normal engine operating temps.. its just a piece of mind.. but dont rely ont it as a sole source of cooling..
Old Mar 25, 2002 | 09:00 AM
littlebluecrx's Avatar
when I used to run the heat in my crx the damn car would run lean, could not figure it out, I put a fuel pump relay, in bypassed the main relay, problem went away, on my car fuel pump would get 10 volts with stock harness, with relay 13.8, car never went lean after that go figure, Jason
Xhoops23
11
Jul 24, 2013 11:27 AM
Cmorcivic
Engine Management and Tuning
May 15, 2013 07:42 PM
LL_SP4RROW
Jun 3, 2011 10:00 AM
Fuster_Cluck
Jan 12, 2007 09:32 PM
sporkcrx
Apr 1, 2004 10:11 AM
