RPM activated switch for IAB?
Old Jun 19, 2002 | 01:22 PM
jamal-188's Avatar
Default RPM activated switch for IAB?
Gonna get a p28 ecu for my hondata equiped GSR, I remember reading that it's possible to make a rpm activated switch to open the secondary runner, anybody konw how to do this. I was gonna get a Victor X manifold but I dont' think it will make that huge of a different running 10psi for now, prob can use the money on something more useful now if I can get my factory manifold to open up.
Old Jun 19, 2002 | 01:25 PM
dustin's Avatar
Default Re: RPM activated switch for IAB? (jamal-188)
You just cut power to the IAB solenoid at the chosen rpm and it will engage the short runners.
Old Jun 19, 2002 | 01:29 PM
jamal-188's Avatar
Default Re: RPM activated switch for IAB? (dustin)
sorry, but what I guess I really wanted was something that would be automatic instead of me flipping a switch.
Old Jun 19, 2002 | 01:30 PM
dustin's Avatar
Oh I know. I'm just saying that you actually cut signal to the solenoid rather than send it to "engage" the short runners. it's not like VTEC where you send power to engage vtec....
Old Jun 19, 2002 | 01:36 PM
jamal-188's Avatar
ok, makes sense now! Do you know what I could use that would do this at a certain RPM? Sorry, I'm kinda ignorant when it comes to this stuff, maybe I would be better off buying the Victor X?
Old Jun 19, 2002 | 01:49 PM
falcongsr's Avatar
What is this crap?
donest someone like MSD make RPM dependant switches?
Old Jun 19, 2002 | 01:51 PM
dbman96's Avatar
New User
Default Re: RPM activated switch for IAB? (falconGSR)
MSD makes RPM switches...
Too bad hondata doesn't have any user-controllable outputs... unless yours happened to have a shift light output, which you could put on a relay to ground the IAB wire at a set RPM.
Old Jun 19, 2002 | 01:53 PM
dustin's Avatar
Default Re: RPM activated switch for IAB? (dbman96)
Hehe the shift light thing is a good idea as an auxiliary output dbman96...
Old Jun 19, 2002 | 03:53 PM
Xerxes's Avatar
New User
too bad the hondata shift light also lights the CEL, I just don't like the way seeing the CEL light up at high-rpm affects my heart-rate
-Xerxes
Old Jun 19, 2002 | 04:49 PM
dustin's Avatar
Default Re: RPM activated switch for IAB? (Xerxes)
Heh, you can cut the wire ... then you lose the CEL but who needed that thing anyways
Just don't throw a code or you might automagically disengage your secondary runners hehe
Old Jun 19, 2002 | 05:19 PM
Sonny's Avatar
Yeah, shift light as an aux output is a very clever idea!
Sonny
Old Jun 19, 2002 | 06:30 PM
Smashback's Avatar
You'd need an RPM activated switch and a relay. If you go to any place that does stereos/alarms they should be able to fix you up on the relay. What will happen is the RPM switch will send voltage to the relay, and in turn the relay will make a break in the wire to your IAB deal.
I did the same thing on a mobile phone car kit. When my phone would get a call, the car kit would send voltage to a relay that would cut the power signal to my stereo's amp, that way I could just talk and not worry about turning off the stereo.
[Modified by mplex2000, 3:31 AM 6/20/2002]
JamieLangdo
Sep 26, 2008 07:08 AM
G2integra217
Apr 16, 2005 09:46 PM
satan_srv
Oct 4, 2003 06:37 PM
stingray2772
Jan 6, 2003 10:23 AM
zmr
Mar 12, 2002 11:29 PM
