:: routine checks - what does everyone check? ::
Old Sep 11, 2003 | 08:58 PM
ID_ten_T's Avatar
Default :: routine checks - what does everyone check? ::
i was just wondering what everyone does for daily/weekly check on their forced induction motors. here is what i look at on a regular basis:
- oil level
- spark plugs
- vacuum lines
- ic piping
- and then i look for anything out of the ordinary
so what do you look for? anything else i should check? thanks h-t!!
Old Sep 11, 2003 | 10:25 PM
Foozball26's Avatar
Default Re: :: routine checks - what does everyone check? :: (ID_ten_T)
coolant and overflow tank
Old Sep 12, 2003 | 01:21 AM
lazerus's Avatar
Default Re: :: routine checks - what does everyone check? :: (Foozball26)
every time i go to get in my car i just glance under the engine bay on the ground for puddles, and make sure my tires arent flat.
let it warm up and beat the **** out of it till im ready to stop.
once a week i would end up checking oil levels, checking for any rubbing on coolant/oil/drain lines and loose bolts, and of course for anything looking suspicious.
Brad
Old Sep 12, 2003 | 05:52 AM
quikB18B's Avatar
Default Re: :: routine checks - what does everyone check? :: (lazerus)
Oil Level
Intercooler Pipes
Coolant
Vacuum Lines
Loose bolts/nuts
Under the car for leaks
Just about every day
Old Sep 12, 2003 | 06:21 AM
TRE_'s Avatar
oi level
coolant level
vacuum lines/fittings
exhaust bolts
any leaks
brake/clutch fluid
spark plugs and wires
just about every other day i check all of those things, and just look around, for anything that doesnt look right. i'd rather be safe than sorry.
Old Sep 12, 2003 | 06:32 AM
VTC_CiViC's Avatar
Default Re: (glowing_turbo)
I was super **** with the Civic. About every other day I'd check the plugs, oil, coolant. Then about every 2 weeks or after a hard pounding I'd give it a compression check.
Yea it may be obsessive, but chances are if you catch a problem early enough, you can stave off disaster!
Old Sep 12, 2003 | 06:47 AM
baphomet's Avatar
Default Re: (VTC_CiViC)
Do you guys do all the things the helms says under service schedule? ie. inspect suspension, driveshaft, boots, lube hinges and locks etc. I am about to do my 75k service so I can save $200+ and was wondering how neccesary it is and what everyone else does.
Old Sep 16, 2003 | 11:36 PM
ID_ten_T's Avatar
Default Re: (b3435)
i thought of another one, check tire pressure.
Old Sep 17, 2003 | 08:17 AM
Pengo's Avatar
Default Re: (ID_ten_T)
yea tire pressure cuz it'll prob be low when u least expect it
all fluids under the hood every coupla weeks along with spark plugs and wires
floor for any leaks, return line for any drips.
compression every 3 weeks to a month
other maintanance stuff i do quickly wenever i'm already under the car and am stuck on a stubborn bolt or nut and need a break. (which is alot more frequently than the manual asks for)
Old Sep 21, 2003 | 08:30 PM
cornhusker's Avatar
when you check your coolant/overflow, what exactly are you looking for?
Old Sep 21, 2003 | 08:43 PM
R6Elmo's Avatar
Default Re: (cornhusker)
WHen checking the overflow, you make sure it's in between the min and max lines.
Old Sep 21, 2003 | 08:45 PM
evoeone's Avatar
Default Re: (R6Elmo)
since i just got a wideband, ill just use it fr tuning, but if you have acess to one, or can pay someone like 10$ just for a few WOT runs, it couldnt hurt, mayber an injector could start clogging up, or fuel pump dying etc
tfeagley
Feb 9, 2009 07:16 AM
lilshady6796
15
Jan 13, 2009 05:40 PM
rollydc69
Apr 6, 2006 08:16 PM
AJxr
Feb 8, 2006 11:19 PM
