Rough on and off throttle transition
Old Mar 8, 2009 | 02:11 PM
zach1288's Avatar
Default Rough on and off throttle transition
I have just noticed lately that when i let off the throttle in a lower gear or push the throttle it is rough/jerky. I am tuned on Crome and my car seemed to run alot better about a month ago. I have just noticed this lately. Its not extremely rough but it is annoying and its hard to drive smooth.
Old Mar 8, 2009 | 02:36 PM
SilverEk3dr's Avatar
Default Re: Rough on and off throttle transition
sounds like you might have a TPS going bad on you, or possibly out of adjustment.
Old Mar 8, 2009 | 02:38 PM
zach1288's Avatar
How do you calibrate it?
Old Mar 8, 2009 | 03:07 PM
U need a voltmeter/dataloging equipment. Then set it to .5 volts when fully closed. That will only work if you already replaced the tps screws, so that you can loosen & move it.
Also. I dont know about chrome but I do know that s300 (hondata) has the ability to calibrate it through the ecu. Might wanna research that some.
jksmith
Feb 19, 2009 09:39 AM
Black R
Oct 6, 2008 10:45 PM
turbotime
Oct 24, 2005 09:11 AM
StinkyTofu
Apr 17, 2003 05:50 AM
shamoo
Jun 18, 2002 12:07 PM
