idle jump up and down
after changing my stock gsr intake manifold to blox intake manifold, my idle jump from 1000-2500. anyone know the reason that cause this? can low coolant cause it? IAC sensoR? let me know thanks!!
Re: idle jump up and down (civic92si)
make sure your using the right TB gasket. spray around with carb cleaner to make sure there is no big leaks.
does it do this under a load? if so, check you TPS.
otherwize http://www.ef-honda.com/ben/Badidle.php
