Rod and main bearing clearance question
Old Mar 15, 2004 | 03:45 PM
Chiovnidca's Avatar
Default Rod and main bearing clearance question
For those who set their bearing clearances, do you set them to the loose side of spec? (For a turboed engine.)
Old Mar 15, 2004 | 04:13 PM
grndcont's Avatar
Default Re: Rod and main bearing clearance question (Chiovnidca)
i always try to be right on spec, loose if i have too. but never tight, i've seen alot of burned bearings.
Old Mar 15, 2004 | 05:10 PM
Chiovnidca's Avatar
Default Re: Rod and main bearing clearance question (grndcont)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grndcont &raquo;</TD></TR><TR><TD CLASS="quote">i always try to be right on spec, </TD></TR></TABLE>
Right in the middle of spec?
Old Mar 16, 2004 | 10:19 AM
grndcont's Avatar
ya, like not too far off from the proper size. i forget the window they give you, but i would not try to go a step above or below the proper size.
Old Mar 16, 2004 | 10:22 AM
gitwidit's Avatar
Default Re: (grndcont)
run the cranks at spec and rods a little loose for boost apps
Old Mar 17, 2004 | 08:22 AM
X-Mazda 3 Racer's Avatar
Default Re: (GITWIDIT)
Keeping the clearance loose will make for a more reliable turbo motor, but too loose and you'll find that you may need to step up to a thicker weight oil ( from 10/30 to something like a 20/50 ) This way the oil has more viscosity and can fill the void better and provide extra cushion for your engine components under boost.
Old Mar 17, 2004 | 08:53 AM
USDM 4G VTEC's Avatar
i did my turbo motor builtup a lil loose....
factory wants 1.5
i set it on 2
Old Mar 17, 2004 | 01:37 PM
Chiovnidca's Avatar
Thanks. Going to set them on the loose side, but still within Hondas suggested spec. Think i'll run 10w40 also.
Old Mar 17, 2004 | 02:03 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT &raquo;</TD></TR><TR><TD CLASS="quote">run the cranks at spec and rods a little loose for boost apps </TD></TR></TABLE>
Ring gap and piston to wall clearances should also be a little looser for boost apps.
Old Mar 24, 2004 | 02:29 PM
crxhybrid1320's Avatar
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i did my turbo motor builtup a lil loose....
factory wants 1.5
i set it on 2
What did you set to this spec-
RODS OR MAINS?
Old Mar 24, 2004 | 03:45 PM
99B16Si's Avatar
.o15-.017 comes to mind but its been a while
Old Mar 24, 2004 | 06:17 PM
Default Re: (99B16Si)
b series mains are .0009-.0017, i measured mine today for my turbo engine and was .0010. Is this too tight for mains?
neonkid
Oct 24, 2012 01:57 PM
jdm knight
Jun 2, 2007 08:30 AM
MotorMouth
Jan 1, 2007 10:59 AM
Hooch'n
Sep 1, 2006 11:05 AM
marcussmith26
Jan 28, 2006 01:45 PM
