ring gap way too big ??
Old Jan 14, 2007 | 10:19 PM
dutchman5's Avatar
Default ring gap way too big ??
i m process to built my turbo block
i have 81.5 CP pistons
top .016
second .025
i accident file too much on second ring.
I need to know before put those ring on pistons..
Is it way too big gap ??
Old Jan 14, 2007 | 11:30 PM
Kelly.'s Avatar
I've quit using this account
to me the top ring is to tight, and the bottom ring is alittle on the loose side (but i have seen looser)
id go 19 on the top and leave the bottom alone.
how much boost/power are you tryin to make.
higher boost/hp = looser gap
Old Jan 15, 2007 | 04:30 AM
NJIN BUILDR's Avatar
Default Re: (Kelly.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kelly. &raquo;</TD></TR><TR><TD CLASS="quote">to me the top ring is to tight, and the bottom ring is alittle on the loose side (but i have seen looser)
I agree.I generally use .006" per inch of bore.That would be 3.209 x .006 = .019".
Old Jan 15, 2007 | 05:30 AM
turbo boost's Avatar
Default Re: (NJIN BUILDR)
.019 for the top ring...whats a good gap for the sceond?
Old Jan 15, 2007 | 11:31 AM
dutchman5's Avatar
Default Re: (snowbunny)
I m plan to boost 400 hp
I m going file top to .019 and leave the bottom alone..
other question..DO u guys suggest me to go ahead file other 3 set rings to .019 and .025 ???
Old Jan 15, 2007 | 12:22 PM
Kelly.'s Avatar
Default Re: (dutchman5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dutchman5 &raquo;</TD></TR><TR><TD CLASS="quote">I m plan to boost 400 hp
other question..DO u guys suggest me to go ahead file other 3 set rings to .019 and .025 ???</TD></TR></TABLE>
yes make all the gaps the same.
Old Jan 15, 2007 | 03:54 PM
dutchman5's Avatar
alrite thanks man
Coolero
23
Dec 10, 2009 02:55 PM
VRD^don
Mar 4, 2005 01:32 PM
turbotime
Aug 15, 2004 10:44 PM
Austinbionic316
Dec 8, 2003 06:18 AM
BabyBlueGSRT
Jun 10, 2003 06:05 PM
