Rev limiter Q
In light of this thread: https://honda-tech.com/zerothread?id=139312
If Honda cuts fuel as a rev limiter instead of spark, does everyone with a turbo make damn sure they dont hit the rev limiter to keep from going lean, or is there some other modification that you make to change this? Or am I wrong and its not that big of a problem to do this in the first place?
i avoid the rev limiter
I'm considering either getting an MSD ignition OR the MSD soft-touch rev limiter ($95 from summit) which is designed for cars with stock ignitions..
-Xerxes
-Xerxes
-Xerxes
-Xerxes
go to racelogic.co.uk/ .they have a section on rev limiters and explain why fuel cut is better as long as it cuts fuel 100%.if it is cut 100%,the cylinder will not fire.therefore it could not run lean.they use this technology on the f1 cars and it seems to work.
