Retuning - 30 over to 40 over bore
Old May 15, 2003 | 02:23 PM
PrecisionH23a's Avatar
Default Retuning - 30 over to 40 over bore
You have a hondata tuned obd1 motor thats boosted then change the pistons. Let's say you keep everything the same on your motor but go from a 30 over bore to a 40 over bore. How off will your fuel curves and ignition tables be? Assume that your timing stays the same as it was when it was tuned (distributor is in same position). How long would you say a re-tune take?
Old May 15, 2003 | 09:50 PM
Default Re: Retuning - 30 over to 40 over bore (GudeH23a)
Bump my sexy avatar.
Old May 16, 2003 | 03:07 PM
someone has to know...
Old May 16, 2003 | 03:53 PM
Sonny's Avatar
You are basically increasing displacement a little, so you might need just a hair more fuel. Unless the pistons are exactly the same but larger, I would think the detonation threshold for your motor will have changed a little. A stock cast piston is relatively weak, but there are no sharp edges that invite detonation.
All things being the same, if you went another .010" over vs where you were, you will have bumped your compression ratio up a little bit, too.
Sonny
Old May 16, 2003 | 04:00 PM
Default Re: Retuning - 30 over to 40 over bore (Sonny)
The new pistons are actually custom 40 over's made for 9:1 compression... All specs were included in the design of the new pistons. Anyways, i just wanted to find out what kind of safe-range my motor was in with the old base map so i do not undergo any type of detonation issues.
Bspec18
Oct 4, 2005 03:11 PM
PrecisionH23a
Mar 17, 2005 06:12 PM
GusRock77
Honda S2000
16
Mar 1, 2005 12:24 PM
TurboTegB18c
Aug 23, 2004 09:16 PM
totalimpact
Dec 9, 2003 03:48 PM
