Retorque of ARP's nessecary?
Old Feb 27, 2003 | 06:01 PM
  #26
B20-T's Avatar
Default Re: Retorque of ARP's nessecary? (Flamenco-T)
how much lbs do u torque them at?
Old Feb 27, 2003 | 06:16 PM
  #27
BoostedH23a1's Avatar
Default Re: Retorque of ARP's nessecary? (B20-T)
preludes u have to remove the cams..
Old Feb 27, 2003 | 06:28 PM
  #28
sweet's Avatar
only new studs needs to be re-torque after 10 heat cycles, used studs can be re-install without having to retorque them..
can you imagine if we have to re-torque them everytime we tear the engine apart ?
stan
yeah that definantly wouldn't be much fun for those who need to replace HG's or tear their motor down often.
Old Feb 27, 2003 | 06:30 PM
  #29
Flamenco-T's Avatar
I torqued mine at 70 ft/lb with moly lube
stan
Old Feb 27, 2003 | 06:35 PM
  #30
sweet's Avatar
Default Re: Retorque of ARP's nessecary? (MordecaiPSI)
i normally like to do things by the book/rules cause working with expensive parts and having something go wrong cause the instructions weren't followed really sucks.
BUT i didn't re-torque my ARP headstuds after i installed my head/motor last May.
i torqued them to 70#, and i think i did the strech method with the lube but that's it. i never went back and removed the cams to re-torque the nuts. 22K later and still no problems. although when i put the motor back together or build a new motor i'm going to follow the instructions perfectly just to be sure. removing the belt and cams isn't so bad really. most of us are just lazy.
Old Feb 27, 2003 | 06:39 PM
  #31
servion's Avatar
Default Re: Retorque of ARP's nessecary? (sweet)
My instructions said to torque to 65ft/lb with an aluminum head...
Old Feb 27, 2003 | 06:47 PM
  #32
sweet's Avatar
Default Re: Retorque of ARP's nessecary? (servion)
yes i believe the instructions i had said the same thing, but i did closer to 70# for the added strength. i can't remember if i did 68# or 70# cause it's been awhile.
Old Feb 27, 2003 | 06:51 PM
  #33
IloveNewt's Avatar
"i normally like to do things by the book/rules cause working with expensive parts and having something go wrong cause the instructions weren't followed really sucks.
i torqued them to 70#, and i think i did the strech method with the lube but that's it. i never went back and removed the cams to re-torque the nuts. 22K later and still no problems. although when i put the motor back together or build a new motor i'm going to follow the instructions perfectly just to be sure. removing the belt and cams isn't so bad really. most of us are just lazy. "
Well my mech said basically on all the FI cars theyve done (id assume mostly b series) when he has done ARP's hes never retorqued them and has heard of no probs. What kind acar/engine u got?
[Modified by MordecaiPSI, 3:51 AM 2/28/2003]
Old Feb 27, 2003 | 10:31 PM
  #34
TurboDANDEE's Avatar
i torqued my GSR to 80 lbs. and have no problems yet (knock on wood). I've been street tuning all week, about 15 psi. and no problems with over heating. I put about 900 miles on the motor so far.
Old Feb 28, 2003 | 10:35 AM
  #35
sweet's Avatar
B18C1, built for and used with N2O injection. i went through 11 or 12 bottles last year and put 22K miles on the motor, no problems with torquing the ARP's to 70# and not re-torquing them ever.
but on my next setup for turbo i'm going to go back and do this to be sure.
Old Feb 28, 2003 | 11:55 AM
  #36
IntegD's Avatar
New User
Well **** me..that might explain my problem. Ive got a small bit of seepage at the front corner from the headgasket(thick *** cometic) and I never retorqued my ARP's . Just rebuilt it like 2500 miles ago. I am going to retorque them today so I will get back to you on how it turns out.
Old Mar 3, 2003 | 05:00 PM
  #37
lsvtecvx's Avatar
Default Re: Retorque of ARP's nessecary? (IntegD)
No in my case they did not need to be re-torqued
Old Mar 3, 2003 | 05:10 PM
  #38
93LSivic's Avatar
Default Re: Retorque of ARP's nessecary? (lsvtecvx)
I retorqued mine. Just for peace of mind. Set the wrench at 70 with moly, then went 2k miles and retorqued to 73.
These were ARP studs that have been used prior to the motor assembly.
Old Mar 4, 2003 | 08:58 AM
  #39
servion's Avatar
Default Re: Retorque of ARP's nessecary? (93LSivic)
So, is the standard agreement that 70ft/lb is ok even with our aluminum heads?
Old Mar 4, 2003 | 09:17 AM
  #40
Flamenco-T's Avatar
I torqued mine originally at 63 lb/ft with moly lube, but again, I am getting 2 different answers as far as the torque specs, once and 62 and 82. I just kinda find a median in between to 70lb/ft of torque when I re-torque mine after 1000 miles
I drove mine for 12K miles now, NEVER LEAKED...
stan
Old Mar 4, 2003 | 11:46 AM
  #41
SuperT's Avatar
Its always safe insurance to retorque.
When my motor was assembled torque was set at 80ft lbs with ARP's and moly lube.
After about 50 dragstrip passes I went to recheck the torque and some were as low as 50ft lbs...
There is no harm in retorquing, I recommend it...
Dave
Old Mar 4, 2003 | 09:25 PM
  #42
sweet's Avatar
Default Re: Retorque of ARP's nessecary? (SuperT)
the ARP spec sheet said 65# for the headstuds, but i did about 70#. that was stock sleeves/Cometic OEM size HG (thickness/bore).
if you use a GE sleeved block that's step-decked or O-ringed, i believe that they recommend around 80# and also to use copper seal to help seal the HG fully. then of course you still need to go back and retorque the headstud nuts after they're heat cycled etc. different setups sometimes need different torque specs.
often times it doesn't hurt to torque them a few # more than recommended for the average buildup, considering that most setups that use the ARP headstuds are N2O injected or turbocharged.
either way it's a good idea to go back and retorque them. which is what i'll be doing from now on.
Old Mar 5, 2003 | 05:04 AM
  #43
QCKGSR's Avatar
just bite the bullet and retorque the head, i had to do this for our race mustangs quite often and that requires alot more work like pushrods, vavletrian, tdc for each cylinder and then a valve adj.. the honda head is simple to retorque just put the bottom to tdc on #1 and have at it, just remember to use the dowel holes for t e cams and it will be a whole lot easier just do 70lbs w/ moly i just did my two honda heads last week and i am about to retorque my cylinder head as well... slo they are raping you for 400+ for this job it should be in the two hundo range???
ToTriggerHappy
Feb 21, 2010 07:52 PM
95civhb
Nov 19, 2009 09:01 PM
EARLdaSQUIRREL
Jan 29, 2009 02:19 AM
- BSeRiouS -
Honda S2000
Aug 5, 2006 11:37 AM
IloveNewt
Feb 26, 2003 07:39 PM
