retarding timing question
Old Apr 1, 2003 | 01:00 AM
_Endless_'s Avatar
Default retarding timing question
i know retarding the ignition timing will affect driveability and it will result in hotter exhaust temperature, aside from these will retarding the timing have any destructive effect on a turbocharged b16? in what way?
i'm planning to retard my timing once i put back my turbo coz i'm going to run the hack, how much timing should i take off? i've read an installation article on jrsc in sport compact car and the timing was retarded below 10 degress as per jrsc instruction and i don't know if it's a good idea. any idea?
any help will be appreciated.
Old Apr 1, 2003 | 05:50 AM
Xscream's Avatar
Default Re: retarding timing question (_Endless_)
Retarding will cause less heat if I remember. On my LS I went from 16 base timing to 13 base timing at 6.5PSI and have no issues what so ever with ping/knock
Old Apr 3, 2003 | 02:02 AM
turb's Avatar
Default Re: retarding timing question (Xscream)
what engine management system are you using?
Old Apr 3, 2003 | 05:21 AM
civicudesire's Avatar
look into a msd btm6...........
Old Apr 3, 2003 | 08:44 AM
bottlefedb18c1's Avatar
but the fuel will not be burnt all the way by the time it goes though the exaust post and causes it to burn on it way though the manifold what causes more EGT temps
thats why if your ignition is to far retarted the EGT will climb and i have seen the manifold glow on some cars due to that
mortificationrock
Jul 10, 2007 04:26 PM
aron0903
Aug 4, 2004 12:34 AM
(__________)
Oct 1, 2002 12:18 PM
