Retard timing question..
Old Apr 27, 2005 | 08:50 PM
99RedSi's Avatar
Default Retard timing question..
On my b16 I'm installing my nx wet kit and I was wondering if I should retard the timing for the 35 shot? I'm positive i'm sticking with the 35 shot only so is this necessary? I figured if I use 93 octane pump gas, my Bkr7e-11 plugs, and my bottle warmer to keep the pressure at 1000 psi i should be safe right?
Old Apr 27, 2005 | 08:51 PM
SOHC_MShue's Avatar
Default Re: Retard timing question.. (99RedSi)
Only a 35 shot? Why?
Old Apr 27, 2005 | 08:59 PM
99RedSi's Avatar
I just want to stay on the safe side of things until i upgrade my internals.
Old Apr 27, 2005 | 09:02 PM
SOHC_MShue's Avatar
tuning is key. You can spray way more than that on stock internals.
Old Apr 27, 2005 | 09:56 PM
99RedSi's Avatar
Default Re: Retard timing question.. (SOHC_MShue)
Thanks for the info! Anybody else have any input?
Old Apr 27, 2005 | 10:13 PM
SFWD 1934's Avatar
For the Nitrous, you really do not need to worry about retarding timing until at least the 50hp mark. Even then, you can get away with stock timing. Remember if you do plan on doing that, you might want to look into an MSD box. I.E. MSD Digital 6. Hook it up so the only time you retard the timing is when the nitrous is activated. Also look at your plugs, they are going to wind up being incorrect heat range for you. Shoot for the #5238.
Jason
Old Apr 28, 2005 | 01:00 PM
99RedSi's Avatar
Default Re: Retard timing question.. (SFWD 1934)
Thanks a lot for the help, that sucks that i bought the wrong plugs
Old Apr 28, 2005 | 01:01 PM
dustin's Avatar
I think those plugs will work fine...
Old Apr 28, 2005 | 01:08 PM
99RedSi's Avatar
Default Re: Retard timing question.. (dustin)
I did some research before i bought the NGK BKR7E-11 plugs and they seemed to be what everybody was using so I bought them. Plus these plugs were getting the best feedback from the honda-tech members.
IemSpooled219
May 13, 2009 02:57 PM
Tippyman
Nov 22, 2005 09:11 PM
SOHC_MShue
Nov 30, 2003 07:54 PM
allshownogo7
Feb 18, 2002 10:19 PM
Pinhead
Oct 12, 2001 12:11 PM
