Results from my "5931" formula 409 turbo
I had always been interested in building a turbo charger from scratch so I decided to give it shot.
The objectives of the turbo were as follows:
1) reach 20 psi before 6000 rpm
2) 50+ lbs/min capable
3) T3/T4 journal bearing format
As a basis for the design, I selected the 60-1 and 5831 turbos, respectively.
Since both employ the T31 as the turbine shaft and wheel, I selected the same turbine shaft. For the compressor wheel, I selected the Pure Turbos 59 mm 11 blade billet. I really had not seen many dynos of their product but after a couple of conversations, I decide to give them a try. As for the other components, the exhaust housing is an old Turbonetics stage III 0.63 A/R. The compressor cover is a 4" inlet/2.5 " exhaust TO4S style 0.7 A/R, cut to meet the blade profile.
A pic of the cartridge
The test mule for this build is a 91 Honda civic.
The set-up:
Drivetrain-
Block- B16a
B16a crank
Eagle rods
81.5 mm RS CP pistons (PTW 0.004")
OEM main bearings (bearing clearance 0.0018")
ACL rod bearings (bearing clearance 0.0018")
Head- GSR, stock port, stock valves (rebuilt)
VT- Supertech springs H1002D, and 2002 rsx type-s retainers
Cams- GSR
Intake manifold- Blox (?)
TB- Professional Products 68 mm
Ignition- Stock Dizzy, wires, and NGK 8's
Fuel Delivery- Walbro 255 and ID1000
EMS- OBD-1 converison, chipped P28, neptune'd
Trans- S4C, cable to hydro bracket, and CC stg 4 clutch
Turbocharger-
Turbo- Homemade
Manifold- Mini-ramhorn
Wastegate- Tial 38 mm
Oiling-
GE Vtec sandwich plate
-4AN stainless braid and 0.065" restrictor (feed side)
-10AN stainless braid (return side)
Hotside charge piping- 2.5" Aluminum piping
Coldside charge piping - 3.0" Aluminum piping
Intercooler- Precision 600 Hp
BOV- Tial 50 mm
Map sensor - GM 3 bar
Downpipe- 3.0" stainless steel
Exhaust- 3.0" stainless steel
The results:
409whp@9000 259 ft-lbs@6418
Conclusions:
Well, I did not quite meet my objectives. (I guess I had better not quit my day job)
But on a lighter note, 400+ whp is a lot of fun in a 2100 lbs car.
Thanks to my tuner and friend d-rob for unyielding support and criticism.
Thanks to my friend Natural Aspirations for the reality checks.
Thanks to Pure Turbos for the wheel and the assistance.
The set-up:
Drivetrain-
Block- B16a
B16a crank
Eagle rods
Cams- GSR
Turbocharger-
Turbo- Homemade
Oiling-
BOV- Tial 50 mm
The results:
Conclusions:
Re: Results from my "5931" formula 409 turbo
Hey it is good that you tried to do this on your own....However I was wondering a couple things...
1: What boost pressure did you use to get to 409whp
2: What RPM did you see this boost at?
3: Don't you think that the 3"charge piping may be a bit too large and may also be causing a bit of lag?
Hey either way you achieved some good things you built your own turbo (that you wanted to do) and you also got a super fun ride....
Congrats
Congrats
I think you would have met your goals with a split blade design. The 11 blade wheels like the new GTX turbos are designed for higher boost pressures / turbo speeds (correct me if I'm wrong).
Congrats
Congrats
2) 8000+
3) I don't think the 3" is much of a problem
Thank you
Interesting, judging by the torque it would seem the boost holds relatively steady but apparently it does not. 8000 rpm to reach 20 psi?
I might of missed it, what is your static compression on this motor?
Personally I give you a big for venturing out to do this on your own. Pretty cool in my opinion although you did not see the results you wanted right out of the box.
Quick question about your Professional Products TB, Did you have any problems with it? I recently bought one. is there any modifications I should do to the Throttle body?
A 1.8 would have netted you the results you wanted. I have a 10.5:1 LSvtec with a 3431. Makes over 20 before 6k. Kinda weird with a turbosmart dual stage boost controller, it spikes to 21psi, and fall to 17psi at peak hp, makes 397/312 on a 224x.
I think my problem is the turbine wheel lacks the necessary energy to spin the compressor wheel any faster. See calc below.
The calculation is a bit crude but it is consistent in application. What I see from the calc and the graph is 1 full point of additional boost not making a measureable change in engine output. Whereas compressor wheel limitations are seen when the boost peaks then falls with increasing rpm.
The plot (below) show the CFM vs Pr, an inverted compressor map.
possibly. im looking at my dyno now. in 3rd gear the 3431 made 20psi at 5800rpm (probably faster if a higher target boost was set) and in 4th in broke 20psi at 5000. and this was on a dynojet 224x no load control
Who is Mr Robot?
Still has a very narrow power band
And if the turbo is creeping all the way to redline then you have an issue
It could be
Boost leak
Poor boost control
Boost controller issue (solenoid, how aggressive the boost map is tuned or lack thereof. If a manual controller then it's broken
Poor wastegate placement
Wastegate not properly sized
Wrong spring in wastegate
Turbine wheel/housing improperly sized/too small
There's a lot more it could be and you need to double check everything and start eliminating things off my list. That turbo should spool much quicker and have a much broader powsr band
It could be
Boost leak
Poor boost control
Boost leak already checked
Poor boost control *
Boost controller issue (solenoid, how aggressive the boost map is tuned or lack thereof. If a manual controller then it's broken *
Poor wastegate placement *
Wastegate not properly sized *
Wrong spring in wastegate *
Turbine wheel/housing improperly sized/too small This is what I believe the problem is.
The only difference is the turbo. The H1C did not have a problem. I don't think the set-up is the problem.
The switch to the 71mm turbine is prompted by the results for the H1C and one of theshodan turbos.
Technical question, how does the impeller actually connect? Is the shaft splined or keyed in some way or is it pressed on?
Turbine is part of the shaft
Compressor is held in place by compression (nut) on a tapered shaft.
