Resonator vs adding another inline muffler
Old Dec 18, 2007 | 02:31 PM
  #26
SOHCD16y8's Avatar
Are you getting this bad sound going all the way out the back or just dumping it there under the car?
Old Dec 18, 2007 | 02:35 PM
  #27
Quickgti1.8t's Avatar
Default Re: (THEDirtyDseriesWOOT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEDirtyDseriesWOOT &raquo;</TD></TR><TR><TD CLASS="quote">well ur wastegate controlls exhaust flow
hell maybe even make a cutout with a diaphram and let the vac/ boost controll it </TD></TR></TABLE>
http://www.atpturbo.com/Mercha...e=BCS
Old Dec 18, 2007 | 02:41 PM
  #28
THEDirtyDseriesWOOT's Avatar
sweet.. there u go that wont break..
Old Dec 18, 2007 | 02:54 PM
  #29
SOHCD16y8's Avatar
Not really a fan of how it comes out at a 90.
Old Dec 18, 2007 | 03:06 PM
  #30
mitsuman's Avatar
Default Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">Not really a fan of how it comes out at a 90.</TD></TR></TABLE>
Ya whats up with that.
Old Dec 18, 2007 | 03:36 PM
  #31
Tjabo's Avatar
Default Re: (mitsuman)
Did anyone on here ever try one of these with a turbo setup?:
http://cgi.ebay.com/ebaymotors...ZWD1V
With my non-turbo 2 liter, this is the only thing I've found so far that takes away the annoying-raspy-uglies from a catless system.
The only problem with it is that I just can't find any good information on exactly how much they flow in terms of CFM or unrestricted horsepower. . . When I put mine on, I didn't see ANY difference in my AFRs, but that was with about 140 whp, on a 2.25 system with a magnaflow muffler at the end.
Looking through the thing, I was actually kind of surprised I didn't see a change in my AFRs even with only 140 whp. All of the exhaust has to pass through a perforated cone, and then it is let out into a series of concentric cylinders of varied lengths. Pretty high tech and high quality, I'm just not sure about the power potential with a turbo.
Old Dec 18, 2007 | 04:56 PM
  #32
im stil thinking the e-cutout hooked to the hondata with the tps@ 95% and rpm activation point is the best bet.. still be able to 3/4 throttle it hit boost and pass people on the freeway .. and if u want go faster just stomp it all the way
if u have the s300 controlling the boost u can run like 10psi on the stock exhuast, then when u hit 98% tps past 3500 rpm hondata n02 controll will open the cutout swap to the open dp map and raise the boost level to a 15+ psi for that ummpphh.. i think im gonna try this on my car
Old Dec 18, 2007 | 06:03 PM
  #33
mitsuman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEDirtyDseriesWOOT &raquo;</TD></TR><TR><TD CLASS="quote">im stil thinking the e-cutout hooked to the hondata with the tps@ 95% and rpm activation point is the best bet.. still be able to 3/4 throttle it hit boost and pass people on the freeway .. and if u want go faster just stomp it all the way
if u have the s300 controlling the boost u can run like 10psi on the stock exhuast, then when u hit 98% tps past 3500 rpm hondata n02 controll will open the cutout swap to the open dp map and raise the boost level to a 15+ psi for that ummpphh.. i think im gonna try this on my car</TD></TR></TABLE>
that would be a great way to cheat it at my local track because they do not allow open down pipe so you pull up, burnout at 75% throttle then after you take off its open.
Old Dec 18, 2007 | 08:13 PM
  #34
yah it could work... lol i swear its a leaky exhaust gakset lol
Old Dec 21, 2007 | 05:17 AM
  #35
batboyvaj's Avatar
a quick ques. I haven't put the muffler on yet, but does anyone know how wide the section is where the cat goes?
Old Dec 21, 2007 | 09:30 AM
  #36
spoolin turbo s's Avatar
Default Re: (Quickgti1.8t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickgti1.8t &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.atpturbo.com/Mercha...e=BCS</TD></TR></TABLE>
when was the last time that was in stock?
Old Dec 21, 2007 | 12:40 PM
  #37
PinkMaggit's Avatar
Default Re: (spoolin turbo s)
Find yourself a Z06 muffler that will solve your problem.
Old Dec 21, 2007 | 12:56 PM
  #38
batboyvaj's Avatar
Default Re: (PinkMaggit)
what's special about a z06 muffler?
EDIT: this is why http://www.youtube.com/watch?v=nNYTqeawzd4
Old Dec 21, 2007 | 03:44 PM
  #39
93CX's Avatar
omg, I must have one of these.. anyone actually used one? I dont understand the 90 degree cutout.. I was going to try to build something like this but I'd much rather buy one
Old Dec 24, 2007 | 03:24 AM
  #40
Default Re: (93CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">
omg, I must have one of these.. anyone actually used one? I dont understand the 90 degree cutout.. I was going to try to build something like this but I'd much rather buy one</TD></TR></TABLE>Yeah i dont know why they did 90 degree but you can just buy the vavle and make your own merge angle. Its a great piece but its on freakin back order or something... i would call up ATPturbo.com and see whats up
Old Dec 24, 2007 | 09:11 AM
  #41
yes u can buy the valve bu it self and make ur own y pipe.. would be sweet except it open if u ever hit boost i want a smoother transition
Old Dec 24, 2007 | 09:54 AM
  #42
mitsuman's Avatar
i had one on an old ef b16 turbo. it was awesome, stock exhaust and at the flick of a swtich, open downpipe. Just make sure you get the electric cut out and not the ghetto one where you have to manually unbolt a plate.
Old Dec 26, 2007 | 12:52 PM
  #43
hhee my friends h22 has that ..
Old Dec 26, 2007 | 04:39 PM
  #44
mitsuman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEDirtyDseriesWOOT &raquo;</TD></TR><TR><TD CLASS="quote">hhee my friends h22 has that ..</TD></TR></TABLE>
lol what a pain in the ***
Old Jan 2, 2008 | 03:45 PM
  #45
NAmodified's Avatar
dam i put a resonator on my straitght pipe on my b18 and mad it so much slower!
Old Jan 2, 2008 | 03:46 PM
  #46
NAmodified's Avatar
dam i put a resonator on my 2 1/2"straitght pipe on my b18 and it made it so much slower!
Old Jan 3, 2008 | 09:27 AM
  #47
Unsivil_audio's Avatar
Too bad those things aren't in production anymore. I really wanted to use one with my stock EM1 exhaust.
http://www.youtube.com/watch?v=bjrljs7ZjT0
Old Feb 25, 2008 | 07:30 PM
  #48
batboyvaj's Avatar
have you guys ever heard of this method of TOTALLY eliminating drone? sounds interesting
http://www.corral.net/forums/s...96793
Old Feb 25, 2008 | 08:11 PM
  #49
riceball777's Avatar
Default Re: (batboyvaj)
just put a large magnaflow muffler on there and it will be quiet
i have a full 3" turboback exhaust with no cat and no resonators making 500+whp and the car is super quiet because i run a super large magnaflow 11x5x22 oval straight through muffler
Modified by riceball777 at 9:06 AM 2/26/2008
Old Feb 25, 2008 | 08:37 PM
  #50
batboyvaj's Avatar
what part number is your muffler. i only see 5x11's
