Resonator vs adding another inline muffler
Old Dec 14, 2007 | 10:51 PM
batboyvaj's Avatar
Default Resonator vs adding another inline muffler
Currently I am running a 3" turbo back, 30" resonator (louvered core), magnaflow muffler.
My car is still droning to much and it seems like the resonator did almost nothing. I'm thinking about just taking that out and doing this...I bought another 4x9 magnaflow 18" body muffler to add to my system. I would have to remove the resonator
(I stole the pic below from the welding forum)
Old Dec 15, 2007 | 08:36 AM
Tchleung's Avatar
Are you sure you can fit that large oval underneath the car and still have decent clearence from the body and the ground?
Old Dec 15, 2007 | 08:47 AM
arc_55's Avatar
Default Re: (Tchleung)
yeah i don't think you could fit a oval muffler due to ground clearances, but there are other muffler options that may be less effective although same idea.
Old Dec 15, 2007 | 09:25 AM
all go teg's Avatar
Default Re: (arc_55)
I have the same problem with mine, its just to loud for long highway runs. Iwas thinking about putting in a second muffler but the only place it will fit is in the stock cat location. I was also thinking about putting in a different muffler, like a world sport from Apexi. I think they have an S bend inside the muffler so it will decrease power but i can deal with it if it makes my drive less annoying....
Old Dec 15, 2007 | 05:16 PM
batboyvaj's Avatar
it should, i have a resonator down there that is 4" round. this is 4" wide so shouldn't be too bad. Pretty sure I have at least 9" across. This drone is making me lose my hearing. I was thinking about the moroso spiral flow but it might block off my flow.
Old Dec 15, 2007 | 07:01 PM
m R g S r's Avatar
Default Re: Resonator vs adding another inline muffler (batboyvaj)
if it's drone from inside the car some sound deadening may be more effective than another muffler.
Just a thought.
Old Dec 15, 2007 | 07:09 PM
HiProfile's Avatar
Default Re: Resonator vs adding another inline muffler (m R g S r)
I'm planning on using an e-cutout (of my own design) right before the gas tank. It will be 3" turbo-back with 2 resonators, and will continue past the e-cutout with OEM piping/muffler. It should be quiet as library on a saturday night. I don't mind the noise short-term, I just can't stand it on a freeway. Plus cops here have NOTHING better to do besides write 'modified exhaust' tickets.
You could do the same, except with a normal baffled muffler. I think apexi makes a 3" chambered muffler, so either way you would have options to quiet it down.
Old Dec 15, 2007 | 07:19 PM
batboyvaj's Avatar
I would like to avoid an ecut if i can. I just don't want to deal with those valves getting stuck.
Old Dec 15, 2007 | 07:34 PM
AspectIndustries's Avatar
Default Re: (batboyvaj)
Im debating with all the mention aboved myself as well.
Like MrGSR said, consider sound deadening stuff instead. Much more effective, yet cost would be similiar.
Old Dec 15, 2007 | 09:04 PM
batboyvaj's Avatar
i've tried some rubberized undercoating with a sound deadener in the trunk and under the trunk. didn't help.
Old Dec 16, 2007 | 04:47 PM
rorik's Avatar
Default Re: (all go teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all go teg &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem with mine, its just to loud for long highway runs. Iwas thinking about putting in a second muffler but the only place it will fit is in the stock cat location. </TD></TR></TABLE>
Old Dec 16, 2007 | 05:32 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj &raquo;</TD></TR><TR><TD CLASS="quote">i've tried some rubberized undercoating with a sound deadener in the trunk and under the trunk. didn't help. </TD></TR></TABLE>
the firewall and shock towers are the most effective places to apply sound deadening. try those areas before you give up on it.
Old Dec 16, 2007 | 07:44 PM
hybridsol's Avatar
I have the exact same issue. I debated going with a 3" 'turbo' muffler from Summit (the one with holes in it) but I haven't done it yet.
Summit also sells this "DNA" resonator that has a spiral of wedges inside
http://store.summitracing.com/...w=sku
It looks promising...
The odd thing is, my exhaust isn't LOUD all the time... wierd
Old Dec 17, 2007 | 05:44 PM
Cole D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj &raquo;</TD></TR><TR><TD CLASS="quote">Currently I am running a 3" turbo back, 30" resonator (louvered core), magnaflow muffler.
I run a 3in exhaust with a carsound cat, 18 in resonator and a modified apexi world sport 3in muffler my car sounds almost like stock its only loud when getting on it. I lost probably 20-30hp but its quiet.
Old Dec 17, 2007 | 06:36 PM
batboyvaj's Avatar
i was thinking about adding a moroso spiral flow muffler but didn't want to restrict my exhaust too much. I will be adding this muffler sometime next week and will let you all know how it sounds
Old Dec 17, 2007 | 06:44 PM
m R g S r's Avatar
strip your interior, and sound deaden all the metal before re installing everything.
Than turn up the boos a pound or less and it will make up for the added weight.
Old Dec 18, 2007 | 10:03 AM
THEDirtyDseriesWOOT's Avatar
ANYONE EVER THOUGHT OF RUNING A 3 INCH DP oops caps lock.. to a e-cutout and the stock muffler and pipe form there back..
then splice into the vtec wire to use the 12v signal to enguage vtec and the e-cutout ...
so quiet on part throttle and when u wanna go just hit the gas vtec pops e-cutout opens and the turbo spools its *** off...
now that i think about it the e-cutout might be too slow.. , but i think you could make one with a quicker servo that would work.. ever been on an assembly line those lil servos can be blindingly fast.. discuss..
Old Dec 18, 2007 | 10:05 AM
Default Re: (THEDirtyDseriesWOOT)
or even better if u have hondata s300 or somthingof that sort use the nitrous controlls to activate the e-cutout @ 90% tps @ 3500rpm or so..
seems liek it would work a lil better like that
Old Dec 18, 2007 | 10:20 AM
DA_HONDA_BOY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEDirtyDseriesWOOT &raquo;</TD></TR><TR><TD CLASS="quote">or even better if u have hondata s300 or somthingof that sort use the nitrous controlls to activate the e-cutout @ 90% tps @ 3500rpm or so..
seems liek it would work a lil better like that</TD></TR></TABLE>
i like that cant get no batter then that
Old Dec 18, 2007 | 12:32 PM
rorik's Avatar
not a bad idea to control the e cut out with the computer, but how long would it last being opened every time the turbo spools? Those things really that reliable?
Old Dec 18, 2007 | 01:19 PM
mitsuman's Avatar
Default Re: (rorik)
That would be pretty annoying to run open downpipe every time I wanted to give it some gas getting onto a freeway or whatever. I think its a great idea, but a on/off switch is much more convenient, controllable, and simple. IMO
Old Dec 18, 2007 | 01:34 PM
well hell between the wire put in a on off toggle switch... if u have grandma in the car...
but really if u put it @ 90% tps u can still get on the freeway without full throttle most street setups the turbo spools at half throttle so you would have plenty enough power..
and that brings me to this.. open dp and stock exhaust is gonna be way diff in how much fuel is needed..
so tune the car fully stock exhaust then tune it with open dp make 2 maps when the n02 contorls cut on you can make it goto the secondary open dp map to be really efficient..
that way if u hit boost in part throttle to 80% tps it wont be rich as *****
Old Dec 18, 2007 | 01:37 PM
Default Re: (rorik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rorik &raquo;</TD></TR><TR><TD CLASS="quote">not a bad idea to control the e cut out with the computer, but how long would it last being opened every time the turbo spools? Those things really that reliable?</TD></TR></TABLE>
i havent used one personally just the manual cutout..
ive heard people say they work great some peolpe say they always break..
im sure if u get a good quaility one im sure it wont be cheap.. it will keep on working. like i said those industrial servos on assembly lines go on and off 100's of thousands of times a day only thing we have to do it put them back in sync after a week or so since they tend to slowly get out of sync..
Old Dec 18, 2007 | 01:40 PM
batboyvaj's Avatar
not a bad idea but i really hate mechanical parts to control exhaust flow, just more crap to break.
Old Dec 18, 2007 | 02:20 PM
well ur wastegate controlls exhaust flow
hell maybe even make a cutout with a diaphram and let the vac/ boost controll it
