Resistor-Pack Vs. Radioshack
Old Jun 3, 2002 | 11:15 PM
ion_four's Avatar
Default Resistor-Pack Vs. Radioshack
I bought some 10 Ohm 10 Watt resistors from the shack, but would it be better to use a resistor pack from an older Honda? Are there any issues with overheating the seperate resistors, since there are the fins on the resistor pack housing? Also, how does that actually hook up?
Old Jun 3, 2002 | 11:57 PM
JaeOne3345's Avatar
Default Re: Resistor-Pack Vs. Radioshack (ion_four)
i was also wondering this, where exactly do u install the resistors,..this way seems much more cleaner then a box and wires going everywhere.
Old Jun 4, 2002 | 12:04 AM
dustin's Avatar
The oem resistor pack is a brick of resistors in a large heat sink, so yes it is better.
Old Jun 4, 2002 | 12:12 AM
JaeOne3345's Avatar
Default Re: Resistor-Pack Vs. Radioshack (dustin)
anyone have directions using just resistors themselves?
Old Jun 4, 2002 | 01:35 AM
C-speed's Avatar
Default Re: Resistor-Pack Vs. Radioshack (JaeOne3345)
We used resistors from radio shack.. works just like stock.
Old Jun 4, 2002 | 06:30 AM
ArizonaTurbo's Avatar
I would assume you would need to place the resistors inline with the ecu harness on the negative side of the injector.
Old Jun 4, 2002 | 06:37 AM
5 Liter Eater's Avatar
Just wire a 10 watt 10 ohm resistor in series with the yellow/black wire from each injector. The ceramic portion of the resistor is not conductive and does not need to be sheilded but you need to sheild any bare wire.
Be sure to solder and shrink wrap everything. No bullet connectors here boys.
They get hot, but no hotter than anything else in the engine bay. Been running like this for a couple months now.
Old Jun 4, 2002 | 07:00 AM
falcongsr's Avatar
What is this crap?
Default Re: Resistor-Pack Vs. Radioshack (5 Liter Eater)
if you're feeling really ambitious you can always expoxy heat sinks on the ceramic parts of the resistors...
or epoxy them all together and put a heatsink from a computer's CPU on them.
Old Jun 4, 2002 | 07:01 AM
dustin's Avatar
Default Re: Resistor-Pack Vs. Radioshack (falconGSR)
or use an oem resistor pack
Old Jun 4, 2002 | 07:25 AM
BoOsTeD_eK's Avatar
Being that those resistor packs can be found for $30-$40....why bother with anythign else...what if you buy a bad resistor and it fails while your driving....you can easily fry your ecu or worst yet blow your motor if that injector stops working.
Old Jun 4, 2002 | 08:13 AM
Sonny's Avatar
I used the OEM resistor box.
Sonny
Old Jun 4, 2002 | 08:15 AM
JaeOne3345's Avatar
Default Re: Resistor-Pack Vs. Radioshack (Sonny)
i was just asking..because the wiring jobs i see on the injector packs dont look to shabby (from what I* have seen).
i just dont want an electrical mess
Old Jun 4, 2002 | 08:49 AM
speeds's Avatar
can you show me how to install resistor pack from the older honda? w/ pic. thankx
Old Jun 4, 2002 | 09:06 AM
BoOsTeD_eK's Avatar
Default Re: Resistor-Pack Vs. Radioshack (speeds)
Hondata has it posted on their site...check it out.
Old Jun 4, 2002 | 09:27 AM
Sonny's Avatar
I installed mine this way and it worked good.
Sonny
Old Jun 4, 2002 | 09:49 AM
93LSivic's Avatar
Me too. Heres a pic of where I installed my resistor box. Found a stock bolt on location and it clears the hood prop in the highest position. Also the wiring harness is right there too! Win, Win, situation.
Old Jun 4, 2002 | 02:14 PM
ef civic's Avatar
Default Re: Resistor-Pack Vs. Radioshack (93LSivic)
i thought 0bd1 and 2 use low independent injector's swo you don't need the resistor box please inlighten me?
Old Jun 4, 2002 | 02:20 PM
liam821's Avatar
25 Year Member
Default Re: Resistor-Pack Vs. Radioshack (ef civic)
heres how to wire in the inline resisotrs...
liam
Old Jun 4, 2002 | 02:25 PM
dustin's Avatar
You have it backwards. Obd 0 hondas used low impedence injectors.
Old Jun 4, 2002 | 03:27 PM
xci_ed6's Avatar
It would be difficult to fry your ECU. The resistors are very durable and when they do blow, you know it. They explode! It is really cool. They do handle way more than 10 Watts, how about 20-30 amps or more at 7.2 volts (144 watts+). They get real hot though. When they blow if they will short and you will not get power to the ECU because the fuse going to the risistors will blow.
I never heard of doing this whole resistor thing, but it is a very good idea.
-Dustin
Old Jun 4, 2002 | 04:26 PM
ceemarun's Avatar
Default Re: Resistor-Pack Vs. Radioshack (Autocratic_1st_Gen)
is there a limit on to how long the wires should be? i will have mine pretty far away from the injectors and engine harness, like near the battery. still good, right?
Old Jun 4, 2002 | 04:45 PM
liam821's Avatar
25 Year Member
Default Re: Resistor-Pack Vs. Radioshack (ceemarun)
naw you shouldnt have a problem.
Old Jun 4, 2002 | 04:58 PM
ceemarun's Avatar
Default Re: Resistor-Pack Vs. Radioshack (liam821)
after i install everything, is there a way i can test if its working?
dustin's Avatar
if the car runs, you're good to go
092eg6
Feb 11, 2010 09:00 PM
z6
Jun 19, 2004 06:37 PM
Del_Slowest
Oct 21, 2003 08:20 PM
servion
Sep 8, 2003 10:14 AM
genop
Nov 20, 2002 08:21 AM
