Resistor box question?
Old Jul 3, 2002 | 08:44 PM
fast[R]'s Avatar
Default Resistor box question?
Ok I know I sow this topic befor did a searsh but din't find a diagram how to wire the box, the box I got has a red wire and 4 black wires, how do I wire this thing ?
Old Jul 3, 2002 | 08:48 PM
inspyral's Avatar
Default Re: Resistor box question? (fast[R])
Old Jul 3, 2002 | 08:49 PM
93LSivic's Avatar
Take the wires going to the injectors and cut all 4 feed leads---->connect to 4 black wires of box. Other end of 4 wires from injector harness get tied into the red wire on the box.
Thats it.
*EDIT* Or just look above. I lost that pic.
[Modified by 93LSivic, 12:49 AM 7/4/2002]
Old Jul 3, 2002 | 10:02 PM
Agamemnon's Avatar
New User
Default Re: Resistor box question? (93LSivic)
Does everyone pull a resistor box of another car? From the bottom diagram its looks like you could just make these things....?
Devin, who doesnt know much about electrical devices.
Old Jul 3, 2002 | 10:09 PM
rioninja's Avatar
Default Re: Resistor box question? (Devin)
You can use resisters inline. The oem resister boxes are basically just a bundle of resisters in a big heat sink. Big heat sink = long cool resister life.
Old Jul 4, 2002 | 02:24 PM
fast[R]'s Avatar
Default Re: Resistor box question? (RioNinja)
Thanks for the diagrams
Old Jul 4, 2002 | 04:31 PM
PrecisionH23a's Avatar
hell ya, thanks
Old Jul 4, 2002 | 04:48 PM
poison's Avatar
yes yes, thanks alot for the diagrams.
poison -- who needs this for h22 swap and didn't know it
Old Sep 14, 2002 | 02:45 PM
TurbothisLS's Avatar
Default Re: Resistor box question? (poison)
anyone know what the color the wires for the dsm injectors are? mine have weirdo colors on them.
what color wires from the dsm injectors go into the box? which colors from the dsm injectors go to the signal wire from the harness?
Old Sep 15, 2002 | 05:24 PM
poison's Avatar
Default Re: Resistor box question? (TurbothisLS)
do you happen to know the cc on dsm injectors?
Old Sep 15, 2002 | 06:03 PM
EK22Tim's Avatar
450CC for turbo 5 spd, 390CC for turbo Automatics I have 450's.. What will they do for my H22?? Anything good?
Old Sep 15, 2002 | 08:01 PM
inspyral's Avatar
The polarity of the DSM's clips doesn't matter. They don't get wired into the resistor box directly per se, but rather the box is wired into the injector harness. The injector clips are wired onto the harness(where you cut your stock ones off) downstream from the resistor box.
Old Oct 18, 2002 | 03:52 PM
thermal's Avatar
so as mine. we have the 1G. mine came off a plymouth laser with part number B450L INP-009. these injectors have multi color wire vice black/yellow that everybody is talking about. eventhough inspyral does have a valid point that it should not matter. i'm just a little skeptic because if it doesnt, then why is there an instruction on having the black/yellow wire on the 2G injectors connecting to the black wire on the resistor pack......i'm still confused. i'm not an electrician nor electronic dude......enlighten us please........
Old Oct 18, 2002 | 09:48 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Resistor box question? (inspyral)
Question, why hack the injector harness when Honda has a plug just for this on the drivers side wiring harness?
Old Oct 19, 2002 | 12:00 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Resistor box question? (Mista Bone)
"That plug that has all those wires and just a cap looking thing is actually a power distribtion block. It goes for the IACV power , O2 sensor heater power, all the injectors, and maybe one or two other functions"
Dammit, oh well I tried.
Old Oct 19, 2002 | 10:07 AM
skunk2unerz's Avatar
learned more today...
Old Apr 10, 2003 | 04:05 PM
blufke's Avatar
Default Re: Resistor box question? (skunk2unerz)
bump so Mista Bone will repost his pics.
Old Apr 23, 2003 | 11:12 PM
project dc2's Avatar
**** .. after reading all this **** .. u guys got mee cconfused ..
so .. black wires .. all go to tthe feed leads on the injectors .. but im curious wtf to do about the powre wire, i cocnnect thee remaining 4 to those ?? straaight off the conneector ? how would n ee power get into it ?? .. hondaata instructions are kinda confusign to me too .. im just dumb
Old May 13, 2004 | 05:24 PM
91glassycrx's Avatar
Default Re: Resistor box question? (project dc2)
does anyone have a pic for the 92-95 ex to wire dsm 450 cc injectors
Old May 13, 2004 | 07:19 PM
yellowmonkeyboy's Avatar
good write up and diagram
Old Jun 11, 2004 | 02:56 PM
civperc's Avatar
Default Re: (yellowmonkeyboy)
sorry to bring this back from the dead, but I've heard something about having to check for "continuity" on the wires and the stock harness? I'm totally confused about that.
Old Jun 11, 2004 | 03:04 PM
T-RO's Avatar
Get a multimeter (or voltmeter whatever you call it). Pull 1 yellow wire out of the connector and unplug 1 injector clip. Touch 1 probe of the multimeter to each end, when it reads 0.00 then you have "continuity" which basically means the injector clip corresponds to the end of the yellow wire you have in your hand (its the same piece of wire).
You have to do that cause there are only 4 injectors but like 6 wires in that connector.
PM me if you need more info
Old Jun 11, 2004 | 03:19 PM
civperc's Avatar
Default Re: (T-RO)
awesome, thanks mang!
Infinity_Racer
Dec 5, 2009 11:08 PM
d15bfi
Sep 28, 2008 10:58 AM
rdssk8rcs1
Apr 10, 2008 08:52 AM
7808
Dec 13, 2006 08:52 AM
vladd
Aug 4, 2006 04:28 PM
