.::resistor box with hondata::.
Old May 4, 2005 | 01:14 PM
kevino002's Avatar
Default .::resistor box with hondata::.
I just got 750cc RC injectors peak and hold for my car and my tunner said that I dont need a resistor box when I use hondata S200B, is this true?? my car is obd1 if that helps.
Old May 4, 2005 | 01:16 PM
dustin's Avatar
Default Re: .::resistor box with hondata::. (kevino002)
If they are peak & hold and your car is OBD1, you need the resistor box.
You can verify if they are saturated or peak&hold w/ a multimeter that can test impedence.
Old May 4, 2005 | 01:28 PM
PM-Performance's Avatar
Default Re: .::resistor box with hondata::. (dustin)
if your tuner told you you dont need a resistor box with Peak and holds. I would deff not return to him due to lack of knowledge with tuning Hondas.
Old May 4, 2005 | 01:32 PM
kevino002's Avatar
Default Re: .::resistor box with hondata::. (itr206)
well I will have to see what he says after reading this, I mean the car started and all......
Old May 4, 2005 | 01:35 PM
dustin's Avatar
The resistor box doesn't have much to do with the car starting.
The injector drivers in the factory ECU can only handle so much current. If you run them for too long at above their rated current flow, you can burn the drivers out in the ecu.
It might work for a little while, but eventually your ECU will toast itself.
Old May 4, 2005 | 01:40 PM
kevino002's Avatar
thanks for the info..I will have to look into this.
Old May 4, 2005 | 01:47 PM
Yep Dustin is right. They will work for a period of time. But will eventually burn out
Good test to try is too much current to a rated resistor with a power supply and see what happens. We used to heat them up in shop and throw them to the freshman unknowing it was hottttt as ****. lol.
jdmdikk
Apr 1, 2009 06:13 AM
blackntegra
Oct 29, 2006 11:49 PM
wappid
Apr 2, 2005 08:53 PM
DBallz
Aug 12, 2003 12:44 PM
93LSivic
Mar 25, 2002 08:35 AM
