Remove turbo to drain coolant???!!!???
Old Nov 11, 2002 | 02:20 PM
intekragsr's Avatar
Default Remove turbo to drain coolant???!!!???
damn is there any other way to drain the coolant from the block without taking off the manifold. turbo, downpipe ect..... ???
Old Nov 11, 2002 | 02:24 PM
paulzy's Avatar
Default Re: Remove turbo to drain coolant???!!!??? (intekragsr)
blow the head gasket
Old Nov 11, 2002 | 02:26 PM
intekragsr's Avatar
Default Re: Remove turbo to drain coolant???!!!??? (paul_vang)
lol, besides that
Old Nov 11, 2002 | 02:27 PM
DeepSi's Avatar
Can't you drain it from the bottom of the radiator?
Old Nov 11, 2002 | 02:30 PM
4gen's Avatar
Default Re: Remove turbo to drain coolant???!!!??? (DeepSi)
Flamenco-T's Avatar
Kyle,
you can;t compeltely drain all coolant out, there's still gonna be some left over at the water jacket of the sleeves...
you can drain all in the radiator, ,coolant bypass hose and water pump area....
what happened ?
Old Nov 11, 2002 | 03:03 PM
intekragsr's Avatar
Default Re: Remove turbo to drain coolant???!!!??? (Flamenco-T)
well my car is overheating intensely so now i am trying to change the thermostat and flush the cooling system. is it bad that there is still some coolant in there? or can i just change out the thermostat without draining the block? as of now I am taking off my downpipe
Old Nov 11, 2002 | 03:10 PM
Flamenco-T's Avatar
well, just drain the coolant out of the radiator and chaneg the thermostat.
and when you;re done, you can do a straigth flush...leave the car running at idle...use a garden hose and fill the top of the radiator and unscrew the radiator plug on the bottom...
do it for like 5-10 minutes....then screw the bottom plugs and fill it up and bleed all the air out of the system....
Old Nov 11, 2002 | 03:15 PM
intekragsr's Avatar
let water flow into the radiator while the car is on? i thought i needed a flush kit or something
do i let the car run with water runnin and after thats done, then remove the drain plug?
[Modified by intekragsr, 12:15 AM 11/12/2002]
[Modified by intekragsr, 12:17 AM 11/12/2002]
Old Nov 13, 2002 | 02:33 PM
Lei Siew Long's Avatar
have you tried taking off the drain bolt on the block itself?. it is a 19mm bolt to the left of the manifold.
Old Nov 13, 2002 | 11:15 PM
intekragsr's Avatar
Default Re: Remove turbo to drain coolant???!!!??? (boostedeg6)
Hehe thats what im talking about. The turbo sits right in front of that bolt.
Old Nov 13, 2002 | 11:28 PM
Pat's Avatar
Pat
I was wondering how you turbo guys drained the coolant in the block completely. I was thinking that you would just drain and fill the radiator a few times over a period of month and eventually the old coolant will be replaced by the new coolant. But then there is contamination issues?!
Old Nov 14, 2002 | 12:21 AM
PrecisionH23a's Avatar
very good information
Old Nov 14, 2002 | 10:05 PM
Sprockets's Avatar
I'd like to know this as well please.
Old Nov 14, 2002 | 10:36 PM
Flamenco-T's Avatar
Default Re: Remove turbo to drain coolant???!!!??? (Evil Beaver)
when the thermostat open and the fan comes on, the coolant system re-circulate itself. by doing it for 20 minutes or more, ,you'll eventually remove all the coolant out of the system...
that's the reason why I suggested to use the running water out of garden hose and use that as a source of water with the drain plug off, then once the fan comes on a couple of times, you'll eventually flush out the coolant from the system....
once you see clear water comes out of the drain hole on the radiator, you can substitute the water frrom garden hose to an antifreeze mix and keep doing it until you see coolant comes out of the drain hole, when you do, plug the drain plug back on, then do normal filling as you normally would...
do this while the car is running, so you're recirculating the coolant out of the system...
Old Nov 14, 2002 | 10:41 PM
FBP Si 2000's Avatar
Something to keep in mind.
Old Nov 14, 2002 | 10:45 PM
gtcali's Avatar
How about take out the thermostat, and put back the housing. Unhook the bottom radiator hose and the top. Put the water hose on the top radiator house and flush the block out . In the top out the bottom til clear. While the engine is off too. Oh and don't forget to drain the radiator too.
Old Nov 14, 2002 | 10:49 PM
paulzy's Avatar
Default Re: Remove turbo to drain coolant???!!!??? (gtcali)
doesn't it flow the other way? I coulda sworn it did
Old Nov 15, 2002 | 09:24 AM
gtcali's Avatar
Yeah it does flow the other way, but with the engine off the pump isn't running. I should be easier than putting the hose on the bottom and draining out the top hose. You're just flushing it out.
BUT MIND YOU I havent flushed out my honda motor yet. Only flushed out my old Celica and old Nissan motor, and a small block chevy. I always gone from the top to the bottom. I assume its the same principal.
That's how I'm gonna do it since I blew my head gasket a couple of weeks ago, and after I fixed it I just put water in and drove it. There is still crap (a little oil) lingering when I open the radiator cap.
[Modified by gtcali, 6:30 PM 11/15/2002]
Old Nov 16, 2002 | 09:59 AM
Sprockets's Avatar
Thanks for the reply. So with the drain plug removed, the engine running and a hose running water into the radiator it's completely safe? Then take the hose out, pour coolant in until coolant starts to flush out instead of water, then plug it? Doesn't sound too bad.
By the way, I don't know you or anything, but I just read they caught the guy who stole your car! That's great news man! Especially since the insurance company was trying to weasel their way out of paying you. I hope everything's still intact!
mjf6866
Nov 10, 2010 07:37 PM
SeanK325
Jun 22, 2010 02:52 PM
Rvu
Jan 29, 2010 08:15 AM
MrViet
Oct 20, 2009 09:43 PM
mikestypeRR
Nov 17, 2005 01:11 PM
