Relay fuse blows......
Old May 2, 2007 | 09:24 PM
BDaTurboTeg's Avatar
Default Relay fuse blows......
I was driving my car one day when i hit a really nasty hole in the road and then all of a sudden my car shut off... come to find out that the fuel relay fuse blew. Well i replaced the fuse and thought everything would be ok but then i tried to drive it again and it cut out. I cant figure out what the problem is.... anyone have an idea?
i have a brand new walburo 255 fuel pump installed
Old May 3, 2007 | 04:14 AM
morning bump....
Old May 3, 2007 | 08:10 AM
ProJectCvic's Avatar
Default Re: (BDaTurboTeg)
check for short circuits.
Old May 3, 2007 | 07:45 PM
ya i was just talking to a friend and it might be shorting out by touching the sheet metal in the tank.... if so then its easy... if not then anyone else have a clue?
the circuits by the fuses are ok and on the pump itself....
Old May 5, 2007 | 05:22 AM
ok found out it is def hitting the metal in the tank...
problem 1 : i cant drop my tank...full tank n not enough time
problem 2 : dont know if i can put clamp around the connector to stop it from hitting
did, or does, anyone else have or had this problem wit there fuel pump?
Old May 5, 2007 | 06:09 AM
Jared's Avatar
pic?
Old May 5, 2007 | 07:13 AM
why do you need to drop your tank? You have a 96 integra reading from your sig...just remove the back seats and pop out the pump to work on it.
Old May 5, 2007 | 09:05 AM
ik i dont need to drop my tank but to fit these clamps on it i dont think it would fit through the access hole....
but i just found out that its not hitting and everything is ok...
so now i really dont know why its blowing the fuse...
i just ordered a new turbo, mani, and wastegate so after i get those on im going to drive it to see if the fuse blows again...
if it does then i well repost with more info
Modified by BDaTurboTeg at 5:38 PM 5/5/2007
97civic07gsxr
15
Jan 14, 2009 06:25 PM
btbomb
Oct 10, 2007 03:22 PM
SiRay13
Oct 9, 2006 09:58 AM
halozero
May 16, 2006 02:11 PM
OldSchoolCrxSiR
Mar 24, 2002 09:34 AM
