Redyno with Tial install?
Old Nov 11, 2002 | 01:23 PM
ski_rebel_3's Avatar
Default Redyno with Tial install?
I have a new Tial 35mm wastegate at home that I am going to use to replace my deltagate. Question is...will I need to redyno/retune because I am switching over to the Tial or can I just continue to run with my current settings?
Old Nov 11, 2002 | 01:26 PM
*Boostwerks*'s Avatar
Default Re: Redyno with Tial install? (ski_rebel_3)
as long as you arn't increasing the boost, there should be no reason re tune.
Old Nov 11, 2002 | 02:33 PM
FredoSP's Avatar
Default Re: Redyno with Tial install? (Bryson)
That sounds good, just keep a heads up on your gauges etc, just to be safe.
Old Nov 11, 2002 | 02:38 PM
DeepSi's Avatar
As long as they have the same spring rating , then you wont. but if the spring is higher psi, then you will need to. Unless you are using a boost controller, then it does not matter.
-deepsi
Old Nov 11, 2002 | 04:42 PM
Default Re: Redyno with Tial install? (DeepSi)
Right now boost is set a 7psi. The spring in the Tial is .45bar but I have a turboXS manual boost controller.
theo99gsr
Aug 1, 2005 09:11 AM
Harassing Herbs
Mar 1, 2004 08:31 PM
booscivic
Sep 5, 2003 02:34 PM
01ITR#700
Jun 22, 2003 10:01 AM
DOHCarp
Jun 29, 2002 11:30 AM
