Recommendation On Cleaning Carbon Out Of Engine
Old May 10, 2002 | 02:49 PM
slowcivic's Avatar
New User
Default Recommendation On Cleaning Carbon Out Of Engine
Could someone please recommend to me a product or method of cleaning carbon buildup inside a GSR Engine from running too rich an a/f mixture? Thank you.
Old May 10, 2002 | 03:00 PM
Rain_man's Avatar
New User
Default Re: Recommendation On Cleaning Carbon Out Of Engine (slowcivic)
Honda Top End Cleaner, available at the dealership. You'll probably need the induction tool too, which is 36 dollars.
Old May 10, 2002 | 03:02 PM
GSRwBOOST's Avatar
4th gear pull on the freeway... WOT...BLOW that carbon out.. LOL
Old May 10, 2002 | 03:12 PM
Doodoo's Avatar
Default Re: Recommendation On Cleaning Carbon Out Of Engine (GSRwBOOST)
I was thinking sort of the same thing, blow a headgasket. shiny!!
j/k
[Modified by Doodoo, 6:13 PM 5/10/2002]
Old May 10, 2002 | 03:20 PM
DIRep972's Avatar
Smarter than you
hhaha I clean the carbon out on a daily basis!
Old May 10, 2002 | 04:24 PM
iww's Avatar
iww
Default Re: Recommendation On Cleaning Carbon Out Of Engine (DIRep972)
pour some water down the intake. Not alot a very small amount. Have you ever seen a piston after a headgasket blows and water seeps in the chamber? Shiny. If this method is to scary do the top engine cleaner.
Old May 10, 2002 | 05:05 PM
inspyral's Avatar
Default Re: Recommendation On Cleaning Carbon Out Of Engine (iww)
What about the ATF with that detergent stuff(dexcron/mercon something or other) in it?
Old May 10, 2002 | 07:34 PM
Jared's Avatar
It's not actually the water that cleans the pistons, its the antifreeze. I've never used the Honda top end cleaner, but the GM top end cleaner works great. Don't worry about using it, it's not made by GM, just repackaged and sold by them. For all I know it may be the same **** that Honda sells.
Old May 10, 2002 | 08:02 PM
slowcivic's Avatar
New User
Default Re: Recommendation On Cleaning Carbon Out Of Engine (DarksideDC4)
Honda Top End Cleaner it is, thank you!
Old May 11, 2002 | 07:02 AM
GruvyTune's Avatar
New User
what's the induction tool??
Old May 11, 2002 | 11:19 AM
Rain_man's Avatar
New User
Default Re: Recommendation On Cleaning Carbon Out Of Engine (GruvyTune)
The induction tool allows you to release the cleaning fluid into the intake manifold at a slow enough rate that you won't hydrolock your engine.
Here's a pic, it's the thing that's screwed onto the bottle of top end cleaner.
Here's a pic of the nozzle, with it's tiny opening.
Old May 11, 2002 | 12:24 PM
TheShocker's Avatar
Red X's
Old May 11, 2002 | 02:16 PM
inspyral's Avatar
Default Re: Recommendation On Cleaning Carbon Out Of Engine (94hondahybrid)
So the white fitting just hooks up to a vac line?
Old May 11, 2002 | 02:27 PM
Rain_man's Avatar
New User
Default Re: Recommendation On Cleaning Carbon Out Of Engine (inspyral)
Yep. All I did was disconnect the brake vacuum line from the intake manifold. Instructions are on the can on what to do. It was a pretty noticble improvement for me after I cleaned it, but I have 100k on my engine. My engine also dynos at exactly what it should be for stock which is great for an old car.
Old May 11, 2002 | 04:00 PM
slowcivic's Avatar
New User
DarksideDC4, thanks for your explanation and pics!!
Old May 11, 2002 | 05:25 PM
inspyral's Avatar
Sweet, how much does the cleaner run at the dealer?
Old May 12, 2002 | 04:18 PM
marklamond's Avatar
Do you have a Honda part number for the cleaner and induction tool?
Is this going to have any ill effects on a turbo or oxygen sensors (probably not)?
Old May 12, 2002 | 04:42 PM
JJ-Built's Avatar
hey slowcivic,
i like to use water injection by ERL, this stuff will cool the charge intake air, resist the presense of detonation, lowers your Nox emission and also steam out the combustion chamber and clean out all the carbon. but if you don't have the royalty of aquiring one, just simply use the HONDA TOP engine clean. ATF and water will do the job just fine. but beware!!! you can hydrolock the motor and bent a rod if the job is not done right......
Old May 12, 2002 | 05:27 PM
csufweed's Avatar
Default Re: Recommendation On Cleaning Carbon Out Of Engine (jjgotboost)
Get some good ol CARB cleaner from pep boys or something, spray small amounts into your throttle body while pulling the throttle. You'll get lots of smoke out the exhaust and a cleaner engine.
Old May 12, 2002 | 10:52 PM
Rain_man's Avatar
New User
Default Re: Recommendation On Cleaning Carbon Out Of Engine (marklamond)
Part number for the Top End Cleaner is 08732-9008. It's about 4 dollars a bottle. The induction tool is 08732-9010. I'm sure it's o2 sensor safe, because why would Honda make something that wasn't? The directions don't mention removing the o2 sensor prior to cleaning either.
Honda also makes a throttle plate cleaner and that does a separate job from what the top end cleaner does.
Old May 13, 2002 | 12:31 AM
ILOVEGIRLS's Avatar
can the top cleaner be used on other cars other than hondas? i have a toyota pick up that needs that stuff bad!!
Old May 14, 2002 | 06:40 AM
slowcivic's Avatar
New User
Hey, thanks everyone for your input and suggestions! I also heard that if you are running too rich for awhile, its best to change your oil more often than you normally do. Thanks again, everyone!!
Old May 14, 2002 | 06:47 AM
TGUNNER's Avatar
A quick 150 shot of nitrous will clear everything right out!!! lol
Old Jan 13, 2004 | 07:36 AM
Havokmkr's Avatar
Default Re: Recommendation On Cleaning Carbon Out Of Engine (Jared)
Just to clear a few things up. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">It's not actually the water that cleans the pistons, its the antifreeze.</TD></TR></TABLE>
Yes it is actually the water that cleans out the carbon. Water isn't compressible within the cylinder, that's why you hydrolock, and the carbon clings to it as it leaves, via the exhaust valve. You can get the same effects as the honda top end cleaner w/a little spray bottle and a few mists of water, as long as you're extremely careful. Another cheap alternative is seafoam. You can mix it in w/your oil and let the car run until it dies. Wait a minute start it back up and your car will smoke for another 5-10 minutes, then you're clean.
Old Jan 13, 2004 | 08:15 AM
Muckman's Avatar
Moderator in Chief
I had my IM hot tanked to clean up all the carbon crap. It cost me $10 at my machine shop.
