rebuilt motor startup
Old Nov 24, 2008 | 12:11 PM
0ne-Cam's Avatar
Default rebuilt motor startup
im not sure if this is the right place to ask this question, and i did use the *search* but couldnt find anything..
i just got done putting my built motor in a 91hatch. is it possible to crank the motor without the injectors spraying fuel into the cylinders? do i disconnect the injector plugs? does that stop all the fuel going into the cylinders? im want my oil pump to get some oil flow before the initial startup
Old Nov 24, 2008 | 12:16 PM
philafelman's Avatar
i personally pull the EFI fuse and crank. im sure others have many different ways.
Old Nov 24, 2008 | 12:25 PM
b20beast83's Avatar
pull the under dash fuse for fuel pump
also disconnect the dizzy connector
Old Nov 24, 2008 | 12:51 PM
tegman23's Avatar
I always pull the injector plugs...crank it a couple times..plug them back in and your good to go...and no fuel will not go in without the injectors pluged in..
Old Nov 24, 2008 | 02:01 PM
0ne-Cam's Avatar
got my motor to crank a few times. i put in my p28 ecu, tried to fire her up but she just cranks/turns over. bolted up the CEL ground, and its throwing 2 codes, first is just two flashes, and second is 2 fast blinks.. code 22 maybe? any suggestions for the startup will be apreciated, my fuel pump primes so im getting fuel. not sure about the firing order, i know its 1-3-4-2, but what about on the dizzy, searched around but cant find out how the wiring looks like on the distributor
Old Nov 24, 2008 | 03:20 PM
0ne-Cam's Avatar
anyone?
rlembitz
Dec 24, 2010 09:04 AM
Mostecstreethb
Oct 29, 2007 11:06 AM
Sinner
Jun 8, 2003 03:03 PM
Sinner
Jun 6, 2003 02:25 PM
TRuST
Mar 22, 2002 11:10 AM
