Rebuilding need advice...
Old Mar 4, 2003 | 01:29 PM
9200RPM's Avatar
Default Rebuilding need advice...
Ok, I have a B16a and I'm rebuilding the bottom end. The motor is in a 94 Civic Coupe, and I'm trying to figure out which way I'm going to go. I ordered some SRP 10.5:1 pistons, but I have a .0043" head gasket so it will be around 10.0:1 compression ratio. I going to have the deck closed and zero balanced (also Eagle Rods). I have been thinking a n2o Wet System or a Turbo Set up. I've been told good and bad on both sides. So I hope you guys can help me out. Thanks in advance....
Old Mar 5, 2003 | 08:00 AM
9200RPM's Avatar
Default Re: Rebuilding need advice... (TurboB16aEG)
bump...
94egcoupeturbo88
Dec 9, 2006 01:00 PM
psegs80
Aug 17, 2006 03:57 PM
1PT-SICK
Apr 29, 2006 06:47 PM
jdmjeff
Feb 19, 2005 09:18 PM
RuffGsR
Feb 27, 2004 04:48 PM
