????????Rebuild oR leave it as is????????
Old May 6, 2007 | 08:07 PM
SiTR's Avatar
Default ????????Rebuild oR leave it as is????????
Well i recently rebuilt my block for boost with wiseco 9:1 pistons and eagle h beam rods. I didn't like the loss in power or the fact that i ruined a type R, so i put a 75 wet shot of n20 for now and ran a 13.6 on street tires. Now im wondering if i should still go boost or rebuild it with stock compression and run like a 75 direct port. My goal is to break into the 11's and have it as my daily still. What should i do? And what would be the most to spray with out a dirct port system? Mods besides the pistons/rods are, clutch, flywheel, i/h/e, and a fuel pump on a chipped p28.
Old May 6, 2007 | 10:52 PM
SiTR's Avatar
Old May 7, 2007 | 01:04 AM
91jdmhatchback's Avatar
Default Re: (SiTR)
Well it all depends on if you care to have the power all the time? Or do you caree if you have to go turn on the bottle and then make sure it is always filled with nitrous...
If you only care if it is an 11 second car at the track then go for the nitrous... but if your like me and want your power to be there 100% of the time then go turbo...
Old May 7, 2007 | 06:06 AM
Schister66's Avatar
Man U FTW
if you want to waste your time w/ a 75shot, snag a stock engine, but since you have a built motor, i'd invest in a turbo setup
Old May 7, 2007 | 09:34 AM
SiTR's Avatar
Thanks for the input guys.
xtremecoupe
Dec 8, 2005 05:06 AM
shazbot
40
Oct 5, 2004 10:15 AM
Civic driven01
Apr 16, 2004 07:20 AM
Modifiedinteg
Nov 27, 2003 05:27 PM
The_Robster
Nov 4, 2002 10:26 PM
