Re: VTEC and Turbo
Old Sep 29, 2002 | 09:57 PM
  #26
SiR Kid's Avatar
New User
Default Re: VTEC and Turbo (ImportReview)
If VTEC doesn't help boosted applications, then why aren't there more 11 second ZC's... Cause I KNOW there are alot of 11 second B16a's!
Also, I've got ITR cams in my car, with stock cam gears. I've got VTEC set at 6000 and at 1/4 throttle, when it switches to VTEC, my tires break loose, and that's at only 7 PSI.
VTEC helps airflow. Period.
[Modified by SiR Kid, 12:58 AM 9/30/2002]
Old Sep 30, 2002 | 06:41 AM
  #27
VTC_CiViC's Avatar
Default Re: VTEC and Turbo (b18onboost)
The theory behind VTEC itself doesn't change at all. Valves open sooner and longer and more = more air, which in turn = more power. The only difference is, you want to reduce the overla between the two to tune down any blow-by. But any way you slice it, a turbo, super or any other method of FI only served to amplify what already exists. Yes you can cam a B18B to produce sick top end like a C1, but will it idle and run at low speeds nearly as well as a C1? Not by a long shot... same thing with the turbo, only to a higher degree.
Try not to think of turbo changing anything really, only serving as an amlifier to an engine, might make it a little easier to understand why the whole conspiracy theroy behind "VTEC is bad for turbo" is not true.
bad_asz_mushak
Dec 14, 2003 09:38 PM
APP95bomexLS
Jun 1, 2003 07:18 PM
hondanacura4life
May 19, 2002 07:58 PM
Toretto
Mar 11, 2002 02:48 PM
