RC Injectors causing rough idle?
Old Jun 18, 2017 | 04:13 AM
cityofcaterpillars's Avatar
Default RC Injectors causing rough idle?
I'm running RC 750cc injectors. I have a sporadic misfire at idle. I've read that this is kind of a common thing with RC injectors. My question is is there any way to fix this and is it bad for the car? I included pics of my map in Hondata.
Setup is
d16z6 .75 over
8.8:1 wiseco pistons
Greddy 18G Turbo
Walboro 255 pump
stock rail and FPR
Old Jun 18, 2017 | 08:31 AM
DickensA's Avatar
Default Re: RC Injectors causing rough idle?
Not the injectors unless they are very dirty.
I run 1000cc injectors and my idle is solid at 14 afr at 800 rpm
Old Jun 18, 2017 | 08:33 AM
DickensA's Avatar
you should have a saddle area for fuel.
You dont idle in one cell. Its interpoolating between 4. Make those four cells the same and the sorrunding ramp up
Old Jun 18, 2017 | 08:35 AM
Originally Posted by DickensA
Youre timing map looks pretty weird
are you at 1 degree btdc at idle?
I'll have to look. It shouldn't be. I haven't touched the timing aside from 1 degree per lb of boost.
Old Jun 18, 2017 | 08:36 AM
DickensA's Avatar
Sorry i didnt notice you posted the fuel map in percentage
post your timing map and your ignition corrections for idle
Old Jun 18, 2017 | 11:43 AM
I've never messed with the ignition Comp either.
Old Jun 18, 2017 | 01:05 PM
DickensA's Avatar
Go into the idle parameter
it should be an ignition timing table for idle
Old Jun 18, 2017 | 03:40 PM
This one?
Old Jun 18, 2017 | 04:13 PM
DickensA's Avatar
Yup change the ign from -5 to -10
and from 5 to 10
that should help keep your idle steady then mess with the fuel to get it where you want
Old Jun 18, 2017 | 04:20 PM
and from 5 to 10
Ok I will give that a shot. Would you mind explaining exactly what that does?
Old Jun 18, 2017 | 04:25 PM
You mean these ones correct?
Old Jun 18, 2017 | 06:29 PM
cruizinmax's Avatar
The parameters mentioned, I don't believe would cause a miss at idle. Only keeping it from going higher and lower.
How wide is your plug gap? Copper plugs? A/f ratio at idle?
Old Jun 18, 2017 | 07:12 PM
I believe .30 for gap. They are the OEM NGK'S. A/f is between 38.9 to 4.7. I'm having trouble getting it to be stable for some reason. It seems to happen more when it's up around 14.7. Like I said the miss is very sporadic.
Old Jun 18, 2017 | 09:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
If your A/F is around 14.7:1 with RC (Lucas style) injectors, it is likely that the engine will stutter sporadically. If you richen the mixture up to the 13.0-13.5:1 A/F range, the idle will clean up... however, this may foul your spark plugs if the car idles for long periods of time.
Old Jun 19, 2017 | 02:26 AM
I've read that other places too. What causes this
barraea
Engine Management and Tuning
Jun 15, 2016 06:45 AM
01typerboi
Dec 23, 2010 12:42 PM
civickiller
May 12, 2010 02:10 PM
95integrags-r
Jun 12, 2003 10:37 PM
dbman96
Jul 18, 2001 10:14 AM
