rc injector sat. non sat.
Old Aug 31, 2004 | 10:08 PM
tegon-gsr's Avatar
Default rc injector sat. non sat.
Im getting a jrsc and i wanted to no what i should get my friend says that i have to get peak holders or something like that and i was told by other people to get saturated injectors what is the diffrence and what should i get i have a 1995 gsr with a b18c1 motor
Old Aug 31, 2004 | 10:11 PM
DRIVENRacing's Avatar
Default Re: rc injector sat. non sat. (tegon-gsr)
sat injectors do not require a resistor box, and peak & hold low imp. does... however with the peak n hold your fuel is tends to stay cooler.. it all depends on what ems you are going to run n what fuel setup your are going to run.. Personaly im going with the 750 RC Sat. Injectors because they are cheaper
Old Aug 31, 2004 | 11:46 PM
tegon-gsr's Avatar
Default Re: rc injector sat. non sat. (TurboHybridEG6)
Im planing on running hondata as my fuel Mang.
Old Aug 31, 2004 | 11:48 PM
tegon-gsr's Avatar
im not looking to make anythiong over 230 i will be making around 210 215 with a 8 or ten pund pully tunned with hondata. so i dont want to get such a high # injector.
Old Aug 31, 2004 | 11:54 PM
ATS*Mark's Avatar
OG triple OG
440s will be good for ur setup
Old Sep 1, 2004 | 03:41 AM
tegon-gsr's Avatar
Default Re: rc injector sat. non sat. (Hella_JDM)
so 440's with out the resinator box the 440 sat. will work
Old Sep 1, 2004 | 11:30 PM
yea id go with the dsms.. cehapest best way to go... i ran 450s dsms 9 psi not 1 problem...
Old Sep 2, 2004 | 04:37 AM
turbopimp's Avatar
You should use saturated injectors on a 95 teg since the factory ecu was designed to drive them. Hondata still uses for factory injector drive circuitry.
jdm95
Sep 17, 2009 01:27 AM
civictypenos
Aug 30, 2003 06:00 AM
GOLDBERG
May 6, 2003 05:00 PM
civcexcoupeblack
Dec 16, 2002 01:16 PM
PM-Performance
Nov 4, 2002 08:40 AM
