RC injector question
Old Jan 23, 2011 | 08:08 AM
import-tooner's Avatar
Default RC injector question
Okay, so I bought a set of used RC 440cc injectors for my civic. I was told they are saturated so I can just plug them in place of my stock injectors. I'm installing my JRSC and these were the next thing to go in. Problem is, the harness plugs won't plug into them. My car is a 98 civic with a 97 integra gsr swap. So, its OBD2. I thought these injectors could possibly be for OBD1 but not sure. Does obd1 and obd2 have different plugs for their injectors??
Other question is, can I buy new seal kits for RC injectors?
here are some pics of the differences.
Old Jan 23, 2011 | 08:20 AM
sanman000719's Avatar
Default Re: RC injector question
buy some connectors and splice them in there is a thickness differance in the prongs inside the injector port noticably.
as far as saturated or not i couldnt tell ya myself im not injector savy
Old Jan 23, 2011 | 08:51 AM
lsneo's Avatar
yes they are saturated
http://www.jazzproparts.com/SL4_440_...cura%20rsx.htm
Old Jan 23, 2011 | 08:53 AM
then its as simple as getting connectors for them and wiring them in
Old Jan 23, 2011 | 09:26 AM
Okay, what kind of connectors do I get? OBD1? Also, how do I get new seals for them? Would a seal kit for a stock injector work?
Old Jan 23, 2011 | 09:36 AM
donno you may need to get the numbers off the injectors go to rc website and see what they say to use but if you have an obd1 setup, and obdo injectors im not to sure that will cross over myself someone else with more knowledge of this will need to answer that ?
Old Jan 23, 2011 | 09:37 AM
00Red_SiR's Avatar
All Motor Mentor
Yes, you need OBD1 injector clips.
Old Jan 23, 2011 | 09:38 AM
slvrlude's Avatar
RC engineering sells injector harnesses that are plug and play for obd2, which im pretty sure you are running obd2...check xenocron.com
Old Jan 23, 2011 | 09:39 AM
so will the obd1 clips tie into and work with obd2 setup
Old Jan 23, 2011 | 10:30 AM
00Red_SiR's Avatar
All Motor Mentor
Yes. Injectors are just solinoids that are either on or off. So they all have a 12v wire and a ground, it's just the clips that are different between OBD1 and OBD2.
Old Jan 23, 2011 | 10:32 AM
Just found this!
http://www.phearable.net/shoppingcar...ips-p-103.html
Old Jan 23, 2011 | 10:58 AM
dpetro1's Avatar
just get the obd1 clips and solder them in. $50 for adapter harnesses is a little pricey IMO. as for the seals you can just get an oem injector seal kit (either from the dealership or napa)
Old Jan 23, 2011 | 11:19 AM
good information for the op and me as well thanx
Old Jan 24, 2011 | 08:26 PM
Do you guys know if you have to put spacers under the fuel rail now that the injectors hold it up higher off the intake manifold?
Old Jan 25, 2011 | 04:47 AM
dpetro1's Avatar
RC's instruction sheet says that only d-seires should need fuel rail spacers. PM me your email and I can send it over if you want (PDF document)
Old Jan 25, 2011 | 06:43 PM
I got the set in there and I'll for sure have to have spacers. I'm going to make some. They'll need to be around 14mm tall.
Old Mar 11, 2015 | 03:43 PM
Alfred Liu's Avatar
Sorry to revive an old post, but just wanted to mention you can just use obd0 connectors to run the RC Injectors or buy the EV1 clips. If you use the obd0 clips, all you have to do is unpin the obd2 clips from your harness and put the pins into the obd0 so no cut/solder is needed. Save the obd2 clips just in case you go back to stock.
EJ8 GSR-T
Apr 26, 2006 06:33 PM
Franky
Aug 25, 2004 12:30 PM
chris@allmotor.net
Oct 19, 2003 04:39 PM
aesthetics82
Apr 2, 2003 05:39 AM
Chuckles
Nov 14, 2001 02:22 PM
