rc 750cc too big?
Old Jun 14, 2006 | 04:39 PM
teddy_dc2's Avatar
Default rc 750cc too big?
i want to get my car tuned but get injectors before any of that, i was thinking about getting 550 cc but push more with rebuilt internals and a head job by summer's end, will 750's at a lower duty cycle be fine or stick with 550's?
Old Jun 14, 2006 | 04:45 PM
95GSRTT
Guest
Posts: n/a
Default Re: rc 750cc too big? (teddy_dc2)
they will be fine.
Old Jun 14, 2006 | 04:47 PM
teddy_dc2's Avatar
does it affect performance to have them run at a lower duty cycle?
Old Jun 14, 2006 | 05:44 PM
95GSRTT
Guest
Posts: n/a
Default Re: (teddy_dc2)
not if you have a competent tuner
Old Jun 14, 2006 | 06:36 PM
blackeg's Avatar
Default Re: (95GSRTT)
as long as you have a way to control them and a decent tuner, they are not too big. you will thank yourself later on should you want to increase the power
Old Jun 14, 2006 | 07:33 PM
jdmbb6-t's Avatar
id go with 750cc, so that you can have room to upgrade later down the line.. like everone said if you have a good tuner he can make the injectors flow nicely regardless of the size.
Old Jun 14, 2006 | 07:40 PM
Zakar's Avatar
1000's or bust!
Old Jun 14, 2006 | 08:00 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Zakar)
750's are great. not too large, give you room to grow, and when i had them, it idled like stock. my 1200's are a different story.
Old Jun 14, 2006 | 08:22 PM
StolenTeg's Avatar
Default Re: (boostedcivicsir)
**** i wish i got rc 750cc , thesse 550cc aint cutting it
Old Jun 15, 2006 | 07:50 AM
teddy_dc2's Avatar
my injectors are ticking, it's untuned just stock at 5 psi, if i were to throw them 750's in, they would still be running at the 240 rate and the ticking would go away? or will they still tick?
Old Jun 15, 2006 | 03:20 PM
Zakar's Avatar
you cant change the injectors without engine management ( or reprogram) or SAFC
but yes.. you will be fine running the 750's at a lower duty cycle until you want more power. then you retune and dont have to change anything
Old Jun 15, 2006 | 05:31 PM
mike93boost's Avatar
Default Re: (Zakar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar &raquo;</TD></TR><TR><TD CLASS="quote">you cant change the injectors without engine management ( or reprogram) or SAFC
but yes.. you will be fine running the 750's at a lower duty cycle until you want more power. then you retune and dont have to change anything</TD></TR></TABLE>
1000cc or bust
deez92
Oct 14, 2021 07:46 AM
Mxl973
May 2, 2017 01:08 PM
B18 rider
Aug 8, 2008 10:51 AM
all-mtr-teg
Apr 16, 2007 08:32 PM
blykins
31
May 4, 2004 06:41 AM
