RC 310cc injectors
Old Sep 8, 2003 | 08:47 PM
B_1_8_hatch's Avatar
Default RC 310cc injectors
how much boost can you run on a b18b with the rc 310cc injectors? i was thinking of running 10psi now that i got the injectors. will i be fine running that amount of boost?
also..i have a 98 b18b1...will i be able to use the clips from a 93 dx motor so i can put the injectors on my motor?
thanks
Old Sep 8, 2003 | 09:05 PM
meanteg's Avatar
New User
Default Re: RC 310cc injectors (93hb)
10 psi no problem at all.
Old Sep 9, 2003 | 03:34 PM
Default Re: RC 310cc injectors (meanteg)
any info on the clips? will i be able to use the clips off a stock 93 dx motor and wire them on to my b18b motor so i can plug them onto the injectors?
10psi with no problems at all...what if i'm using a small td04 greddy turbo...can i turn it up higher with no problems, or will 10psi be the max i should go on stock internals?
Old Sep 9, 2003 | 06:14 PM
89civic1.8T's Avatar
I ran 10 psi on my B18B with a greddy turbo and it hauled ***! I would say 12 psi would be safe as long as you A/F's ratio's are staying where they should be. If you have control of your timing under boost make sure you are taking off 1 degree/psi and make sure you A/F is in the 11:1 range and you will be fine. You may make more power with more timming and less fuel but then you could be asking for trouble.
Old Sep 9, 2003 | 06:22 PM
GraphiteAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb &raquo;</TD></TR><TR><TD CLASS="quote">how much boost can you run on a b18b with the rc 310cc injectors? i was thinking of running 10psi now that i got the injectors. will i be fine running that amount of boost?
thanks</TD></TR></TABLE>
What management are you going to use with the 310's? FMU?
Old Sep 9, 2003 | 07:06 PM
for right now...yes, a vortec fmu.
TurbodTegSfaria
Nov 14, 2006 04:07 AM
mitchellP
Oct 7, 2005 06:47 PM
LuderCriS
Jul 26, 2005 02:37 AM
ZygSpeed
Jan 2, 2002 09:44 AM
