random misfire error code on high speed low rpm
Old Nov 12, 2019 | 05:34 AM
hondafanornot's Avatar
Default random misfire error code on high speed low rpm
hi there. i recently observe a strange behavior and would like your expertise advice.
scenario 1: while going 60mph at around 2k rpm in 5th gear, i floor it to cause engine hesitation as it moves to 2.5k-3k rpm range. it builds boost but slowly and engine check light is on for few seconds, obd2 diag shows random misfire so could it be spark plug? fuel pump? all 4 spark plug replaced recently, fuel pump pressure at 50.
if I downshift to 3rd gear, floor it and it would build boost fast and send the car flying
if I downshift to 4th gear, floor it and it would build boost slower than 3rd and it also goes fast
I can shift 1st to 2nd and send the car to 65mph without misfire and various shifting gears without error
Old Nov 12, 2019 | 07:17 AM
Txdragon's Avatar
Default Re: random misfire error code on high speed low rpm
5th gear boost romp is a no-no. 3rd gear at 60mph is gonna see you in boost range RPM, 4500-ish so, yeah, you're gonna sail. 4th gear will be laggy, yeah. Anywho.. 5th gear isn't liking what you're asking it to do.. Stop it!! Lol!
Old Nov 12, 2019 | 07:23 AM
so who cares about random misfire right? it's bad to put on high gear to spool anyway like u said.
Old Nov 12, 2019 | 07:24 AM
Txdragon's Avatar
Based on the info you've given, it is misfiring in 5th when you're trying to goose it.
Old Nov 12, 2019 | 12:02 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It is likely that the tune isn't spot on at the place in the fuel/timing maps that you are working from when you are at low RPM in 5th gear. For a quicker spool, it is always better to select a lower gear instead of lugging the engine in top gear. ALL cars will accelerate faster in lower gears... so if you are trying to accelerate fast, choose a lower gear.
Blown90hatcH
Aug 25, 2009 04:30 PM
DaZman69
Nov 10, 2005 03:46 PM
Sinner
Aug 20, 2004 06:35 AM
Etylorcen
Nov 15, 2001 11:24 AM
degradated
Oct 29, 2001 07:56 AM
