Ran the B20 turbo tonight, Needs tires and Clutch!
Here are my times from tonight. Let me know what you guys think. I'm happy with what i got concidering my stock steelies do not hook up at all. Also my stock clutch is completly toast... At the end of the track i was at 7,000 rpm's in 5th gear.... So i only had 200 rpms left before reaching my top speed.... crazy huh? But anyways. Car feels like its EASILY into the 12's. I just need a clutch and tires to do so. I'm happy with almost trapping 109 on only 6psi
Setup: On 6psi
B20b w/ GSR tranny + LS ECU (7200rpm)
A/R70, 84ar hot side, 64.5 trim Ballbearing turbo
Equal Length turbo manifold
Tial waistgate with 6psi sping.
JRC FMIC
Greddy TypeS BOV
2.5 charge pipes
Dizzy timng in the middle
4 gallons of 110 & 3 gallons of 93
Vortech FMU 12:1
Walbro255 intank pump
Stock clutch (needs replacement asap)
SLIP # 1
Went off idle, babied it into 2nd then into 3rd but then 3rd roasted the tires horribly so i just stuck it into 4th, then 5th . BAD wheel spin in 3rd...
weight: 2335lbs
r/t .230
60 2.359
330 6.201
1/8 9.113
mph 85.69
1000 11.565
1/4 13.642
mph 108.69
SLIP # 2
same as above, bad wheel spin in 3rd
r/t .124
60 2.202
330 6.033
1/8 8.964
mph 85.17
1000 11.440
1/4 13.524
mph 108.55
SLIP # 3
Let me friend ride with me and lucky the track officials didnt say anything about us too riding in the same car. It didnt spin as bad this time but i had to granny the hell outta each shift (like always) to keep from spinnin or lettin my clutch start slipping.
weight : 2500lbs
r/t .032
60 2.363
330 6.122
1/8 9.062
mph 84.41
1000 11.576
1/4 13.701
mph 106.43
Setup: On 6psi
JRC FMIC
Greddy TypeS BOV
2.5 charge pipes
Vortech FMU 12:1
SLIP # 1
weight: 2335lbs
r/t .230
60 2.359
330 6.201
1/8 9.113
mph 85.69
1000 11.565
1/4 13.642
mph 108.69
SLIP # 2
r/t .124
60 2.202
330 6.033
1/8 8.964
mph 85.17
1000 11.440
1/4 13.524
mph 108.55
SLIP # 3
weight : 2500lbs
r/t .032
60 2.363
330 6.122
1/8 9.062
mph 84.41
1000 11.576
1/4 13.701
mph 106.43
Re: (j boy)
Nice numbers but why the **** are you running that turbo if your only running 6psi? Do you plan on upping the boost in the future? If not, not a great choice IMO. Nice numbers nonetheless.
Re: (SOHC_MShue)
lol, I plan on upping the boost as soon as i go uberdata. But even still the turbo wont be at its potenial. I'm just tinkering now while its at the end of the season. But my goals are in the 500-600whp range with a 83mm sleeved/built LS block. Crower valvetrain + Crower turbo cams, skunk2 manifold, new axles and of course... Lots of tunning
*edited*
Modified by JDM S1eeper at 9:53 AM 10/23/2004
*edited*
Re: (JDM S1eeper)
What transmission do you have? You should be able to go much much faster than 109 in 5th gear. My car gets up to 155 in 5th gear. I realize your probably not reving your b20 that high but still, you should be able to do atleast 140 before redline.
EDIT: Just saw you have a GSR tranny, You can do 109 in 4th gear on that tranny!
Re: (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol »</TD></TR><TR><TD CLASS="quote">What transmission do you have? You should be able to go much much faster than 109 in 5th gear. My car gets up to 155 in 5th gear. I realize your probably not reving your b20 that high but still, you should be able to do atleast 140 before redline.
EDIT: Just saw you have a GSR tranny, You can do 109 in 4th gear on that tranny!</TD></TR></TABLE>
4th gear ends at 90 somthing, I'm going into 5th gear just after the 1/8. since i only have a stock LS ecu my revs only go to 7200 (all i need right now with a stock head anyways)
My revs were at 7k in 5th at the end. the trap on the slip was almost 109 but if you think about it, they track doesnt give you a actual speed. Its an rounded speed they take from i think the 1000 mark to the 1320. Actual speed was easily 115 but my speedo quit working. I also know it shouldnt be at 7k. My clutch I believe had a big part in that. I believe top speed with that tranny and rpm is in the 135-140 range maybe. All i know is if i wanna run better times a clutch and better tires are a must lol
Re: Ran the B20 turbo tonight, Needs tires and Clutch! (JDM S1eeper)
I think I'mma go to that AR Fab dyno meet comming up. (getting a clutch before tho ) I'd like to know what its putting out to trap those speeds My guess is 250whp +/- .
AsianCivicRider
12-03-2011 08:52 PM
JDMs1eeper
10-24-2004 07:32 PM
*Boostwerks*
21
06-14-2002 03:25 PM
